Old 06-29-2026, 10:26 AM
mgarblik mgarblik is offline
It looks like you have enough good parts and seals to put it back together after you clean it up and remove the rust. If your concerned about compatibility of the pistons, one area to check closely is the depth of the counterbore where the booster rod contacts. It needs to be the same depth, +- about .010". If different, I would reuse the old piston. That can effect the ability of the chambers to refill when you release the brake or give you a low pedal or possibly even give you light full time apply if off by enough.
I have had a few situations recently, finding parts and castings that look correct. 1. 1973 SD-455 TA. Wanted a MC that looked exactly the same with the bleeders on the casting. Ended up buying 2 different reproduction MC's and mixed and matched parts to get a great looking and functioning unit. OE casting was rusted beyond honing. 2. 1962 Catalina, power Delco brakes. A new, correct MC was not available, period. This one year MC used a weird wing nut cap and I wanted to retain the correct look. This one I had to send to White Post Restorations in Virginia. It had to be bored, and sleeved with a bronze sleeve. Then honed and drilled for the fluid passages. They do this process daily. Took 3-4 weeks and did a beautiful job. Works great. Perfection comes at a price. Had to bite the bullet and pay $250.00 to have it sleeved and machined. So there is a solution to almost any problem, although it can get a little costly and inconvenient. Looks like you have this one under control now. Good luck with it.
Old 06-29-2026, 11:22 AM
Shiny Shiny is online now
It appears to me that in both instances (cover and seal) that rust lifted the sealing surface and allowed fluid to slip by. This would also jive with the way it just started leaking out of the blue with no use. Went years without leaking, then after sitting for a couple of years in our new humid TN location it just all of a sudden started leaking just sitting there.
Of note is that is rust in both locations where it is leaking.
Correlation is probably more than a hint here. Sorry you had to go through this again but glad you found time.
Old 06-30-2026, 04:34 AM
dataway's Avatar
dataway dataway is offline
Probably my fault, I tend to be a bit remiss when it comes to changing the brake fluid or using sealed containers. Last 45 years I lived in a low humidity location so I didn't pay much attention to it.
I'll get it put back together and report the results. Thanks for the help.
Old 07-11-2026, 09:37 AM
dataway's Avatar
Couple of questions before I button this MC up.
Does the arrangement of the internal components appear correct? That is how they came out. ( I installed them about 7 years ago and it's worked fine).
And, what is the purpose of the large groove at the rear of the MC? It appears to have no function in my application ( all drum, power), also there is a pic of the rear boot I am using.
Also a pic of the cover gasket that was on it, obviously rust had compromised the seal a bit.
Borescope video of the bore after about 30 seconds of honing. Not sure if this will work. https://youtu.be/HNHE-gz7kj8
ID:	673160   Click image for larger version
ID:	673161   Click image for larger version
ID:	673162   Click image for larger version
Old 07-15-2026, 10:57 AM
dataway's Avatar
Just a bump to see if anyone has any input.
Old 07-15-2026, 12:37 PM
That cast body may also do duty as a manual master if machined differently.
The large groove around the outside of the bore most likely is seating for the rubber boot which retained the manual push rod. I was never able to source these boots separately.
I thought this rod retaining design was very poor in comparison to Mopar (deep hole in piston) and Ford (hole with one time locking clip). GM sometime in the early 70's dispensed with the shallow hole/boot design and went to a Ford-style clip. $0.02
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
Old 07-15-2026, 07:04 PM
dataway's Avatar
Thank you, noticed one of my kits had the manual boot.
