Old 07-19-2004, 02:03 PM
Trips4me's Avatar
Trips4me Trips4me is offline
Send a message via MSN to Trips4me
***** (Originally posted under "Valve/rocker and cooling issues" dated July 16.)
"Interesting topic.. It just so happens that I just put my 389 back together after retrofitting my #76 heads to an adjustable valvetrain, Rhoads lifters and Comp Magnum roller rockers (+ new valves, etc). Before it never got over 190 now its' running 190-210. Is there something up because of the valvetrain??? I thought it may be because I was producing more HP but now I wonder?? "
July 19 response....
Did the divider mod, installed a new 160 t/s and the temp did not change much. I checked the radiator while it was out and it seemed to flow very well. I also adjusted the valves once again and the idle A/F. ...it's 97 degrees here today also. I'm running a rebuilt 8 bolt water pump w/ cast impellor as well as a stock fan and fan clutch.
I'd like to get it cooler than that so what's next... a RR radiator??? Do they fit into the stock 1965 GTO mounting brackets??
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's
