Old 09-09-2003, 12:13 PM
BLOWBAYOU BLOWBAYOU is offline
I HAVE A 71 LEMANS WITH THE 350 PONTIAC ENGINE.
IS IT POSSIBLE TO CHANGE THE ROCKER STUDS AND ARMS SO THAT I CAN ADJUST THE VALVES LIKE YOU WOULD ON A SMALL BLOCK CHEVY?
ARE THE STUDS IN MY ENGINE A SCREW IN TYPE OR ARE THEY PRESSED IN?
ANY HELP WOULD BE APPRECIATED.
Old 09-09-2003, 12:33 PM
gotpontiac gotpontiac is offline
We need the casting # from the heads to know what studs are in them. You can use locking nuts and spacer washers to make your rockers ajustable with either screw in or press in studs. If you have a stock cam I would not advise doing it. When I bought my performance Crane cam (272-2) it came with locking nuts and washers to use.
Greg
1969 Firebird/400/th400/3.42:1 rear
1/4=? MPH=? (WIP)
1983 1/2 ton Silverado/lwb/305 (89 FB)/
MSD ign/Mallery coil/83 intake/
700-r4(rebuilt w/shift kit and corvette servo)/
3.73 gears/31x10x15 all terrains.
10.9 1/8 mile. 17.xx 1/4 mile
1996 C2500/6.5L TD/4L80e(shift improved),4" exhaust
cold air intake, mechanical WG controller
3.73 gears/265-75-16 w/Eagle allows.
2002 1500 Suburban/stock
1986 Fiero GT,needs engine.
Old 09-09-2003, 12:31 PM
David Jones's Avatar
What heads are on the 350?
http://kurtspontiac.homestead.com/DavidJones69GTO.html
