Does anyone have info or anything on the RA VI and the RA VII engines?
I'm the Dude. So that's what you call me. That or His Dudeness... Duder... or El Duderino, if, you know, you're not into the whole brevity thing... |
Anything, but mainly pics and specs.
Mark,was not the RA VI and VII 428 and 455 3in main RA Vs?If so I have pics of a complete correct RA VII motor.Its in my garage.Tom
Mark,
What is the significance of the distributor gears in your profile???...Robert |
Has any company thought of doing a revamped RAM AIR V HEAD--In aluminum etc. It should flow some big numbers
BOP recently came out with a composite distributor gear for pontiacs. That's the significance of the gear in his avatar.
********** Don't be jealous that I've been chatting online with babes all day. Besides, we both know that I'm training to be a cage fighter. |
Thanks, Poor...
Seems like a good idea, considering the factory's bad design of 'drain-back oiling' to the distributor gear. I added a galley plug with a .030" hole on my engine to help with this issue, but I don't think my iron camshaft needs a composite gear. Nice to know they are making new stuff!!!...Robert |
I know of a block, built on 428 has GME (General Motors Experimental) on the side, did have the crank, I believe it was like the 990 SD, but ended up installing it in an Early Butler rebuild and delivered it to Dallas Tex. for Drag racer in Houston Area. Can't recall what happened to the heads and intake.
The composite gear is for use with roller cams. I have on in my 400 with a hyd roller. After 3000 miles it still looks like new.
the engine I have in the garage,waiting for a 69GTO,is a correct RA V block,3in main 4.21 stroke forged crank,RA V heads, correct RA V carb,dist,and balancer.The pictured intake was on it for some dyno pulls.I guess that would be the RA VII?Tom
Is that a lot of excess flashing in the rear opening or just the lighting of the picture?
bad pic
I,II,III,IV,V,VI,VII
1,2,3,4,5,6,7 first time hearing of a RA 6 or 7 was there really such a thing?
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
it was a wishfull thinking number,NONE were ever produced.There were 3 3in main 4.21 stroke cranks said to be made and a hand full of 4in stroke 3in mains.Kellog I believe made them for the factory.There were also a few 3 1/4 main angled cap blocks made to run with the 990 SD crank.All develpomental stuff.The only engines actually made were 25 303 RA V SCCA engines and a 100 or so 400 RA V.Don Keefe might be able to ad more or correct my mistakes.Tom
Any idea where that crank forging die may be? Hmmmmm......
Steve www.pontiacheaven.org
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
Steve,both Kellog and Moldex made cranks for Pontiac,they are both still making cranks,call them and ask what happened to the dies.Last used in 1972 or about,bet they were factory dies and went in the same trach our Alu. blocks came out of.Tom
The cranks were forged by a company located
on the west side of Detroit who has gone out of business long ago. This is per Bob Gillian and "Whitey" from Moldex. I suspect the dies were destroyed at the same time the company closed but typically the dies were owned by GM so who knows where they are today. Tom Nell told me the number of 366 crate engines was much higher that the 100 mentioned in Tom S note. Most of the 303 parts initially went to H.B. in Texas and were later bought by Ron Sherman. Tom V.
Tom,I have never seen or heard of a mass produced 366 V motor,know they had the cranks but have never seen a pic of a motor.Tom
The engine that was in Milt's car, I believe, came from that "Crate motor" program through one of Pontiac's parts marketing groups and was not an engineering piece, according to Tom Nell.
If would be like Ford SVO designing and selling parts that did not come out of the normal Ford Engineering system. Ford "Crate Engines" fit that description too! Tom V.
I think the crate motor program was for 400s?I know a guy that has a couple and have talked to MANY people that have either seen or owned the 400 crate motors but never a 366.FYI,Tom
