Old 05-10-2004, 02:06 PM
RRF RRF is offline
I have an exhaust manifold leak with the RAIII repro's on a '73 400 block 4X heads. Since I also have to replace intake manifold gaskets and the valley pan bolt grommets, will the heads remove with the RAIII's still attached?
Old 05-14-2004, 11:23 AM
engineer engineer is offline
should have put antiseize on the bolts when first installed. Easier to remove later.
Old 05-16-2004, 07:11 AM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
I,ve done it more then once... Very heavy.
Better off have a friend lean over the bumper while you take the fender side for control.
You don,t want that falling on your fender
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 05-10-2004, 02:09 PM
goatless's Avatar
goatless goatless is offline
They should come off just fine but they'll be REAL heavy!
1966 GTO
Old 05-15-2004, 08:34 AM
67ramairowner 67ramairowner is offline
Man I would never try that...good way to blow out a disc in your back or drop an nut in your pants....bad idea
Old 05-16-2004, 06:13 PM
disc0monkey's Avatar
disc0monkey disc0monkey is offline
just did it two days ago, my dad took off the first one because he is big, but i took the second one off but i was standing in the engine compartment becuase the radiator and fan is out
RRF RRF is offline
Old 05-11-2004, 07:28 AM
RRF RRF is offline
Yes I figured that, but it may be better than pulling the whole engine out. I tried lifting the block on one side but still could not get leverage on some of the RAIII bolts.
