#641
Old 11-01-2004, 08:01 PM
8point 8point is offline
Send a message via ICQ to 8point
Hey guys, I have been folowing this overheat thing from the beginning and it seems like one thing in common is a motor rebild, could it be deck hight. Every ono trying to drop compression and end up with pistons to far in the hole. I heard that it affects heating.
Jim G.
  #642
Old 11-03-2004, 07:07 AM
convbird convbird is offline
If you don't degree your cam can it contribute to some of these overheating problems. Being an amature engine rebuilder and not owning a degree wheel, I just lined up the timing marks. I have tried everything on this forum, but I still will go up to 240 sitting in traffic, but drop down to 180 moving. Please someone let me know if this was a bad move!
  #643
Old 11-03-2004, 10:12 AM
brujo04 brujo04 is offline
I have had the same overheating problem for months. I am the guy from San Diego that runs Distilled water and Water Wetter.
Tonight I am going to scope my car and test to see if it is a lean condition. All I know abot my motor is that is was rebuilt, not sure if it was bored or not.
Rather then speculate I will put the car on the computerized Sun Scope and get back with the details.
  #644
Old 11-03-2004, 07:29 PM
Malky Malky is offline
68convbird, IMO, degreeing a cam is something you do if you are chasing the last few HP, and it is only done to double check the cam grinder as they have been known to screw up a cam occasionally. I don't think it could cause the gross overheating at idle you are seeing without seriously affecting the car's performance across the board.
  #645
Old 11-04-2004, 04:11 AM
buwalda buwalda is offline
Ditto
  #646
Old 11-04-2004, 06:03 AM
Thanks for the feedback!
  #647
Old 11-04-2004, 07:26 AM
Guys, I have been trying to get to the shop for over 2 months. Yesterday I finially get the car to the shop an it was closed... it is going to have to wait till next week. I'l keep you posted.
  #648
Old 11-11-2004, 10:44 AM
bfrazee bfrazee is offline
I was talking to a guy at work yesterday and he said his girlfriend owns a 89 Camaro and it runs hot. He says it will get up to 220. Do you know if the water pumps in those models are the same design? Any help is appreciated.
  #649
Old 11-11-2004, 12:26 PM
george kujanski's Avatar
Chevies do not use the same type of pump arrangement as Pontiacs.
George
  #650
Old 11-11-2004, 01:26 PM
So it doesn't have a separate plate, which means no modification is possible? I have a 72 Monte, and I've probably changed the pump before. It's all one piece isn't it?
  #651
Old 11-11-2004, 01:43 PM
That's the way I remember it; no mods necessary or possible. I wonder if care must be taken by the rebuilder to press the impeller into the proper position tho... It's been a while since I opened up a Chevy....
George
  #652
Old 11-11-2004, 02:03 PM
I couldn't find any pictures of the pump, so I'll make a new post on the Camaro forum. Thanks for responding.
  #653
Old 04-20-2005, 11:22 AM
2kool4u 2kool4u is offline
hi can you tell me where you got your water pump and if it is cast impellers or steel and the part number so i can get for my 67 gto and i also will tweek minethanks bob my email is [email protected] thanks
  #654
Old 04-20-2005, 12:38 PM
Wow, this thread has come alive. I guess summer must be approaching.
The cast impeller thing seems to be a crap shoot; you just may need to go to your supplier & check his stock for a cast one. From last year's postings, there did not seem to be one mfr or model that was consistently a cast impeller.
George
  #655
Old 04-20-2005, 12:59 PM
I got my water pump from NAPA and it was a cast pump. But that still did not resolve my problem. I believe that the motor was bored and the current system, although in very good shap in not capable of cooling. It is going to take an new aluminum radiator!
Joe
  #656
Old 04-20-2005, 01:25 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Wow, 33 pgs.....
Mine from Napa was a stamped, took me a while to find one.
........I'm just learning as I go.......
  #657
Old 04-20-2005, 03:06 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
Zero decking my 400 helped it run a lot cooler, NO OTHER CHANGES.
  #658
Old 04-20-2005, 03:51 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
I thought I heard of making the waterpump bypass smaller(making more water pass thru the rad)helps cooling.Only saw 1 person in this thread mention this.What does everyone think?
  #659
Old 04-22-2005, 01:15 PM
I need to get a hold of Old Goat 67 i want to ask him where he got his Cardone Water pump for his 67 gto i have one to and i need the place where he bought it name of store or phone no and part number.
Thank You
Robert Warren
  #660
Old 04-22-2005, 01:31 PM
Send him a private message or email to [email protected]
George
