I have a 70 Lemans. I want to upgrade the fuel line to 1/2in. Does anyone make a 1/2in. pick-up that fits into a stock gas tank?
Max, I also have 70 LeMans. Going to 1/2 seams pointless because there is still 8inches of 3/8 pickup tube in the tank.You can pull only as much gas as a 3/8 tube will allow. The pickup tube is connected to the main fuel line, which is also 3/8, by a rubber gas line.The stock fuel pump also takes a 3/8 line. Are you building a faster motor that requires more fuel?A good working stock fuel pump will supply you with plenty of gas.
you can drill out the factory pickup and resolder 1/2" line into your origional unit. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
I have a 72 Lemans and installed a sump in the stock fuel tank and as electric fuel pump and use 1/2" line all the way to the fuel pressure reg. It works great!
Thanks everyone for your input. I ended up drilling out the 3/8 line out of the stock and welding in a 1/2in. line.
