Old 06-11-2001, 08:25 PM
Poncho64 Poncho64 is offline
73 Grandville and 73 Grand Prix, the grandville obviously has 455 and the grandprix has 400. $66 dollars a car. Is that a great deal or what. I am going to pick them up saturday but I want to know one thing, I know they would have to be shortened for my 64 but do these cars have 12 bolt rearends? Also the trans should be 400 turbo's right!
Old 06-11-2001, 10:06 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
Poncho64, The 73 Grandville will have a "long-tail" TH400 & the G/P will have the "short-tail" TH400. The rear in the G-ville wont fit, & not sure 'bout the 73 G/P. Sounds like a deal to me tho!
Old 06-12-2001, 07:30 AM
Kurt Zimmerman's Avatar
Kurt Zimmerman Kurt Zimmerman is offline
Another vote for great deal. Some great engines and parts there. There is a growing number of Grandville restorers, a friend of mine is doing a 73 Grandville convertible. Interior and trim parts are hard to come by.
Kurt
Old 06-12-2001, 09:34 AM
Narrowing the rearend is no problem but I just wont to know are they 12 bolts or not?
Old 06-12-2001, 10:55 AM
The Granville differential utilizes a '71-76 MP series carrier & ring & pinion with a round flat style pinion flange. This ring & pinion is a direct descendent of the 65-70 big Pontiac rearend. No aftermarket gears are avail for either. Used gears... 3.42's were as low as possible for the '71-76 type MP series & are near extinct. Only found on '71 non a/c 3spd 400 & select mountain pkg or trailer package equipped Pontiac big cars.
While both the 65-70 & 71-76MP series utilize 8 7/8" diameter ring gears & are attached with 12 bolts, they do NOT share the common 12 bolt CHEVY 8 7/8" car or truck Ring & Pinions or carriers. The MP series carriers are wider from bearing to bearing & will not fit Chevy 12 bolts.
The '73 GP rearend fits 73-77 A & G series GM cars & will NOT bolt in '64-72 Lemans-GTO or 69-72 GP's. The upper control arm perches are placed in a different spot & are angled wider. If it is original, it will have bolt in axles & is a decent core to build up for a '73-77 GP or '77 CanAm or #1 buyers...'73-77 GM factory stock (circletrack) builders. One can also trim & grind all the brackets off of the housing & correctly weld leaf spring mounts on to get a correct width 2nd Gen Firebird R/E with desireable bolt in axles.
Good deal on the parts cars...just antied up $200 on a 69 GP SJ parts car. 4 hour drive home & a combined 14 hours getting it out of the woods, whew... made for a long weekend.
