Old 06-24-2005, 03:10 PM
clifdog56 clifdog56 is offline
I am about to swap a 455 and 400turbo trans into my 62 G/P are there any pitfalls I need to watch out for?
Old 06-25-2005, 07:15 PM
carcrazy carcrazy is offline
It's been several years but I remember it as noted by wolfs63. No big deal!
Old 06-24-2005, 05:44 PM
wolfs63's Avatar
wolfs63 wolfs63 is offline
I JUST COMPLETED THE SAME SWAP ON MY 62 G-P. I USED A SHORT TAIL TH 400 AND HAD TO RELOCATE THE CROSS MEMBER PLUS LENGTHEN THE DRIVESHAFT.ALSO MINOR FLOORPAN MODS USING A BFH. A VERY EASY JOB.
Old 06-25-2005, 04:03 AM
Blackcat's Avatar
Blackcat Blackcat is offline
Bonker's-T-Cat Moderator
Bolts right in.
However, The stock Roto Hydromatic will last bout 5 min behind it. Best to also swap in a TH400 or the Bonnieville Hydro. Or find a Stick setup for your car.
Try calling CRUSHPROOF! 512-386-9889
Old 06-27-2005, 08:07 AM
goldeneyee goldeneyee is offline
I just made the same change in my 62 Catalina. Use the 389 mounts-it will bolt right up. Go to NAPA and buy mounts. They are about $10.00 a mount. You don't want to use 43 year old mounts. The crossmember will take some creative thinking. Bill
Old 06-26-2005, 09:29 PM
thanks for the tips /should i use the motor mounts from my 398 or those now on the 455
