Old 03-26-2005, 10:46 PM
Ok who is running a set of dual electric fans off of some junk yard car ???
What car did it come off of and how's it working on your set up? Im hitting the yards Monday to look for some things and figured I would add this to the list
Mike
Old 03-27-2005, 01:46 AM
gobrdgo gobrdgo is offline
Mercedes e-fans are first class units.
Old 03-27-2005, 07:40 AM
ponjohn's Avatar
ponjohn ponjohn is online now
Lincoln Mark 8 fans appear to b the highest oem cfm rating I have read about here and on other chevy sights.
Supposed to be in the 4000cfm range BUT they draw close to 30 amps.
Old 03-27-2005, 07:49 AM
Mike,
Windstar dual fans have a very high cfm flow and will package on most "A-Body" radiators with little mods.
They also can be used on "F" body vehicles with some minor bracket work.
Old 03-27-2005, 08:40 AM
dutch injun's Avatar
dutch injun dutch injun is offline
Dual 11"SPAL out of Italy are good too. No problems with them.
Old 03-27-2005, 11:55 AM
onetru462's Avatar
onetru462 onetru462 is offline
Been using Chrysler fans for a couple years now and love them. Matter of fact, word got out and now when I go to the local track I see them all over. I perfer the ones from V6 Sebrings,Intrepids etc(all late models,2002+). Kinda cool as one of the fans are 2 speed, very easy to mount and wire up Keeps my 462's cool no problem even cruising the beach in Florida in the summer months.
---"Reverse-engeneering will always make up for the lack of original ideas!"---
Old 03-27-2005, 12:09 PM
sardegna sardegna is offline
saab fans work well, too. i have one mounted in front of the radiator.
406, 4X, balanced rotating assy, forged pistons, Crane 272, Torker 2, Street Avenger 770, 3.73 posi disk brakes
Old 03-27-2005, 01:22 PM
Andy are they double fans or you have to get 2 of them?
Mike
Old 03-27-2005, 02:19 PM
onetru462's Avatar
They are a double fan all in one shroud. The harness for them is also a 1 piece unit, and it doesn't use the balasts that so many do. They, like others listed, have incrdible amount of airflow. I choose the Chryslers as their v-6 run pretty hot and over the years there fans just kept getting more and more powerful, and the fans are in so many cars that they are pretty easy to find.
Old 03-27-2005, 02:20 PM
onetru462's Avatar
And here is the other style (Which I think is a little better but requires a little more clearence).
Old 03-27-2005, 04:37 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
I have a dual fan set up off of a 97 LT1. Fits nicely on my stock 4 core rad. Another guy I know has the same fan setup on his 67 Camaro with a 454. Keeps it nice and cool for him. Hope it works as well for me.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 03-27-2005, 05:03 PM
cwolf cwolf is offline
Send a message via Yahoo to cwolf
Does anyone have drawings or can explain the best way to hook them up?
Old 03-27-2005, 05:29 PM
onetru462's Avatar
Do you mean phsically locating them or wiring them up?
I wire them up with a themostat switch run through a relay.Can post a basic diagram for that if you need it.
Old 03-27-2005, 05:43 PM
Wiring them up, I like what was posted looks like a good way to save on horsepower.Also would it be better to locate the fans in front or behind the radiator?
Old 03-27-2005, 06:01 PM
onetru462's Avatar
Mount them behind (the engine side) of the radiator. As for wiring them here is a basic relay diagram.Pretty easy to wire anything once you understand a basic relay.
I am just attaching what I made up for a couple of my friends so they would quit wiring everthing straight to there battery or fuse boxes.
Old 03-27-2005, 06:06 PM
Thank you for sending the wiring diagram and location to put the fans, it will be another project that I can do to improve my car to make it a better daily driver when I get it on the road.
Old 03-27-2005, 08:08 PM
DAVE RIBEIRO DAVE RIBEIRO is offline
If you are going to the junkyard,look for the fan off a Buick grandnational..I use one on my race car and it works great...Good-luck
Should be $25-30 bucks.......Dave...1033/stock
Old 03-27-2005, 08:57 PM
Brian '74's Avatar
I purchased a Volvo fan from a seller on Ebay a few months back. Here is a link to one of his auctions than ended:
Ebay auction
He told me he had quite a few fans, but none on Ebay at the moment.
Old 03-27-2005, 09:38 PM
Hey Fbird what size engine you keeping cool with that Volvo fan?
This topic has generated alot of responses.
Does anyone have any pics of their junk yard fans mounted in car? Would like to see what you guys came up with to secure the fans.
Im going to definatley put one on my TA but I have to figure out how to secure the radiator after I remove the shroud.
Mike
Old 03-28-2005, 05:28 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I just picked one up today from a '95 Chrysler New Yorker. Looks like the one in AndyR's second pic. I think it should mount fairly easily to my '68 Bird's radiator support. It's even equipped with a a 2-speed module. Bolt hole spacing is 28 1/4".......the same width as my radiator!!!
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
