I finally got around to installing my '95 New Yorker fans on my 'Bird today. A little more work than I thought it would be. I had to do very minor trimming on the corners of the shroud to get it on the radiator nicely, and made some brackets that mount to the rad. support the same way that the radiator does.
I ran each fan on a seperate relay and switch so I can run them independently. I also used 2-way rocker switches - up is "on", middle is "off", and down will "on" and ran through a coolant temp. switch (temp switch will be installed later). Pics......
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected] Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 - Quickest Pontiac 2022 - 10.13 @ 133.07 2025 - [email protected] - 2nd place SRBBNA
