#61
Old 05-21-2000, 07:29 PM
67TIGER's Avatar
67TIGER 67TIGER is offline
I would like to see the 4 piece rear chrome
moldings for the sail panel that finishes the
vinyl roof.PY Catalog has them for 68-69 and
70-72 but none for 66-67.Come on ,How about
it????
Steve
PROBLEM WITH 64-67 IS THEY ARE STAMPED ALUMINUM. THERE IS NO INEXPENSIVE WAY TO MAKE THESE MOLDINGS. ON THE POSITIVE SIDE, THEY FIT ALL A-BODY CARS, WHICH MEANS ONE OF THE BIG $$ CHEVELLE COMPANIES MIGHT BUCK-UP FOR A PROJECT LIKE THAT.
[This message has been edited by Ccass (edited 05-22-2000).]
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
GTO-The Great One for 1967
  #62
Old 05-30-2000, 11:22 PM
TheTempest TheTempest is offline
How about some front bench seat upholstry kits? Maybe introduce some of the unique Tempest interior patterns (for those rare ones that haven't been chopped up for GTO parts)
Mike
(I'd like to see them also, but there were so few bench seat Pontiacs, we're not having much luck getting interior companies to make patterns. In the meantime, most owners are buying 2 rear seats and an upholsterer can come darn close to making the bench look correct.
[This message has been edited by Ccass (edited 06-05-2000).]
Mike
  #63
Old 06-04-2000, 01:40 PM
gtopaul gtopaul is offline
Like to see a good steet 71 GTO front valance, a rear valance with cutouts that doesn't cost $300, and a factory ram air air cleaner assembly. Any why doesn't anyone repro the 71 GTO grille nameplate? Every other year can be found.
71 GTO front valance, rear valance and air cleaner are all in the works. Price will be much lower than what you are seeing now. Check back end of summer. Also, 71,72,73 GTO emblems are not available because of limited production one year only. Also a 1970 emblem looks identical once installed. Only difference is the attaching pins.
  #64
Old 06-06-2000, 03:36 PM
MoJo's Avatar
MoJo MoJo is offline
The 70 -72 Firebird interior sail panels and lower door panels are very difficult to find in any shape. Would love to see them
reproduced.
""Guitar groups are on the way out", "The Beatles have no
future in show business"
Decca Records rejection of The Beatles - 1962
  #65
Old 06-07-2000, 01:01 PM
MoJo's Avatar
Ram-Air Air cleaners for the 70-74 L78.
Would'nt that be nice for a couple of hundred $ instead of $500-1000 for junkers.
  #66
Old 07-08-2000, 09:25 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
OK PY, you want to make a few more bucks. I have recently tried to get some POA valves for GM/Harrison air conditioning systems. These are about imposible to find. Seems the manufacturer no longer makes or will ever support them. Any chance of seeing these reproduced, or are they in the same boat as '70 GTO/Lemans tail light lenses.
"Run wild with an Indian, not with the crowd in a Chevy"
Check out my restoration at http://members.aol.com/jetmech15/gto
POA valve is going to be a tough one. But there is a serious attempt being made to do the 70-72 GTO lenses!
[This message has been edited by Ccass (edited 07-18-2000).]
Less said,,,,,,,, Less mended.
  #67
Old 07-25-2000, 05:13 PM
Larry 67 Larry 67 is offline
67 GTO Tailight lenses...Pretty new ones without any cracks...that would be a beautiful thang.
Cruise On!!!
Cruise On!!! http://kurtspontiac.homestead.com/Larrys67GTO.html
  #68
Old 07-26-2000, 07:51 AM
mrgto's Avatar
mrgto mrgto is offline
65-67 GTO hoods
66-67 Front Fenders(They would sell like Hotcakes) Don't give me this BS about the 68-69 don't sell. THey made over 150K of GTO's alone those would sell!
Rear quarters for everything. Why are the Chevelles getting all the good stuff. It boggles my mind.
  #69
Old 07-28-2000, 06:44 PM
David David is offline
How about 79-81 Trans am tail light lenses with the correct fuel door!!
__________________________________________________ ________________________
My 79 400 4 speed Formula
either get busy living or get busy dying
  #70
Old 08-07-2000, 07:17 AM
bigunde bigunde is offline
How about door panels for a 71 firebird and
the back arm rest?Thanks
Old 08-07-2000, 01:32 PM
67-69 Bird Front Disc Spindles..."Convert Drum Spindles to Disc; all you need to do is mill about 1/4" off of one Threaded Boss"
Then supply front disc caliper brackets for a complete conversion kit. I do not know if there is an availability issue with the Calipers these days..got two from Pepp Boys in 1992.
69 Bird Manual Steering pitman Arms. Curved would be nice, so Long-Branch manifolds can be used during full right-turning radius.
67-72 GTO and 67-69 Bird Replacement axles:
7/16 studs on Standard pattern with half-inch studs on the 5" pattern. May as well make these axles capable of street/strip.
67-68, & 69 Bird and GTO In-Dash stereos that accomodate the dash centerbar..may as well include 1/8 inch stereo input for remote CD player, Seek/Scan, Must be lighter than GM stereo [img]/infopop/emoticons/icon_smile.gif[/img]
69 Dual bailing wire Brake Master Cylinders made in Aluminum.
SFI approved Harmonic Balancers...without the high price, like under $100.
67-69Bird Headers with 1 7/8 or 2" primaries.
some minor tube bend improvements to boot, like skipping the equal-length foolishness.
  #72
Old 08-07-2000, 06:00 PM
MikeNoun's Avatar
MikeNoun MikeNoun is offline
The one thing that has been frustrating is finding the 69 Firebird front bumper Pontiac arrowhead. Ames had these in "Inquire" mode for the last 7 years, and never did produce any. They recommend buying the 67/68 arrowhead, and making "...some mods to the bumper" (re-drilling holes). Now that a repro front bumper is available, I doubt anyone will actually make the 69 arrowhead, as you have to drill new holes in the repro bumper to mount an emblem anyway.
67-69 Firebird round port headers that actually fit, without going around the frame, scraping the ground, or sticking up through the hood.
Aluminum Rally I and Rally II wheels for us "stealth nuts".
  #73
Old 10-04-2000, 05:12 PM
ghaines ghaines is offline
68-69 rear arm rest bases.
haaarrrrddddd to find.
  #74
Old 10-04-2000, 11:22 PM
MoJo's Avatar
70-72 Firebird Rear Sail Panels,Seat backs,Lower Door panels, Rear panels-
Grrrrrrrrrrrrrrr!
  #75
Old 10-15-2000, 08:07 AM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
Would like to see molded hood insulation for the 65-66 fulsize cars.
  #76
Old 10-16-2000, 10:33 AM
Ccass's Avatar
Ccass Ccass is offline
Administrator
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Doug Hopkins:
Would like to see molded hood insulation for the 65-66 fulsize cars.<HR></BLOCKQUOTE>
Doug, I think you'll see this by next Spring! Keep checking here in the "Performance Years Stuff" section.
  #77
Old 10-19-2000, 07:21 PM
Ccass,I would also like to see carb ID tags (tri-power) for these cars,should be inexpensive to do,and I see a lot of these cars at the shows. Thanks,Doug.
[This message has been edited by Ccass (edited 10-20-2000).]
  #78
Old 10-20-2000, 10:00 AM
steveK steveK is offline
'69 steel TA hood. Ya...cause I need one on a real TA. but do not have $4000 to spend on it.
[This message has been edited by steveK (edited 10-23-2000).]
Steve Karew
  #79
Old 10-22-2000, 01:48 AM
Tim642957's Avatar
Tim642957 Tim642957 is offline
Ditto on the tripower carb tags.
Grand Prix - a world class athlete in a tuxedo
1964 Grand Prix
1966 Bonneville Brougham
1980 Trans Am - original owner
  #80
Old 10-22-2000, 08:23 PM
Ed Neasham Ed Neasham is offline
Tim - What tri-power carb tags are you looking for? I'm looking at my PY GTO catalog and they list '64, '65 and '66 MT and AT tags (Part numbers RPE346, 348, 350, 352, 354 and 356 respectively).
