Old 03-24-2003, 12:48 PM
boboh1 boboh1 is offline
My GTO reads a speed that is far faster then I am travelling. I am not using special or oversized tires, so does anyone know why the reading is off? I would sure like to fix this as soon as possible. Thanks for your help.
Old 09-05-2004, 03:55 AM
buwalda buwalda is offline
If the speedo reads a speed that is higher than the actual car speed, & it is because of tyre size, then it would be because the tyres are undersize [ smaller diameter ], not oversize.
Old 09-03-2004, 04:14 AM
freebird69's Avatar
freebird69 freebird69 is offline
I believe you can order drive and driven gears from either year1 or NPD.
Old 09-02-2004, 10:20 PM
Pzr's Avatar
Pzr Pzr is offline
www.novaresource.org/speedo
good tips in how to determine the different gears driven and drive.
I did.
White pearl firebird -71
Old 03-24-2003, 01:17 PM
David Jones's Avatar
In an automatic. Find out what rear end ratio you have. Go to local GM dealer and get the correct plastic speedo gear for the transmission. Take the speedo cable loose. Remove the retainer clip from the housing. Remove the cover then the gear. Reverse the process. I did it. You can. Unless yours is a manual. Then well, I don't have a clue.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 03-25-2003, 10:56 AM
Thanks for the suggestions. The guy I bought the car from said the transmission is original, but has been rebuilt so I can assume they may have used the wrong gear. At least I know what direction to take.
Old 03-25-2003, 06:38 AM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
I have found that by using this site, you can usually narrow down what is the culprit. Of course benchmarking your speed against a newer vehicle also helps.
http://www.prestage.com/carmath/calc_Gears.asp
- Jim Doran -Some Pics of my 65
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
Old 03-25-2003, 01:14 AM
burgundygto burgundygto is offline
Not all TH400 trannys have the same speedo drive gear in them. Did you change out the tranny? Bring the two letter code and year model from the ID plate (right side of tranny) to the dealer along with rear end ratio. Manual speedo gears change out the same way.
Old 03-24-2003, 01:01 PM
JoeF's Avatar
JoeF JoeF is offline
Most likely, the reason it is not reading correctly is because the rearend gear was changed at some point. A numerically higher gear ratio will make the speedo read faster than you are going. Do what Tom S suggested and it should be fine.
'67 GTO Conv 400 TH400
Old 03-24-2003, 12:54 PM
tom s tom s is offline
take it to a speedo shop in your area,they will put the correcr gear in your trans.Tom
