Old 07-06-2005, 04:54 AM
SWEETJUDGE's Avatar
SWEETJUDGE SWEETJUDGE is offline
how can i tell if i have the correct wiper motor???
im having NOT SO hidden wipers problem, & the wipers are slower than the tortious
im out of adjustment under the cowl & im NOT 100% certain i can reclock the arms themselves
1969 Early 01D JUDGE #s MATCH RA III 4 Spd (Concours Restored)
1969 PRO STREET GTO 2500 lbs. ALL ALUMINUM 505
1969 RARE All Glass GTO (FOR SALE) YOU NEED THIS
AC Cobra Kit Car 521 670 HP/715 Trq
LOOKING FOR V PARTS !!!!!!!!!!!!
Old 07-06-2005, 06:51 AM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
The first question to ask is.....when you
turn the wipers off, do the blades drop down
a couple of inches lower than their lowest point when wiping? If they do not, then either you have the wrong motor(one for a tempest without concealed wipers) or the park switch is
bad in the motor. If the motor is too slow when wiping you probably need a new motor anyway, so
just make sure you buy the right one and everything should work when you install it. You
can only adjust the height of the wipers at the slot on the linkage that bolts to the motor.
The wiper arms will only install in one place
on a 69 GTO, due to a key on the splined shaft on the wiper transmission that fits into a notch in the splined hole of the wiper arm.
Old 07-06-2005, 07:27 AM
SWEETJUDGE's Avatar
thanx for the info, everything on the car so far has been original, it is slow though & probably should be relpaced.
is there a visable difference in motors or a # somewhere to check
& who would you recommend to purchase a new one?????
Old 07-06-2005, 05:05 PM
The Ames catalog I have indicates that a new
one is still available from General Motors. Ames
lists a price of 182.00.
Old 07-06-2005, 09:45 PM
I have a new old stock one but it would cost more than $182.00. The newer ones from GM would probably work well but they will not have the same originality, look, or even part number sticker on them.
I paid over $500 for a numbers matching date coded correct. I would sell my other one for $350.00 plus shipping. It is an original part number with early '70 date code.
Old 07-07-2005, 07:08 AM
racerboy's Avatar
racerboy racerboy is offline
70ramair
How early is the date code on your '70?
ftb
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 07-11-2005, 08:55 PM
Sorry so late. I haven't been on. It is the 79th day of 1970.
Old 07-12-2005, 05:47 AM
gto19's Avatar
gto19 gto19 is offline
where is the date code on the wiper motor?
thanks dudes
Old 07-12-2005, 06:09 AM
racerboy's Avatar
70ramair,
Is that too early for 1970 Judge with an 02B build date?
Old 07-12-2005, 06:11 AM
racerboy's Avatar
Oops, I think I meant B04.
Old 07-12-2005, 06:52 AM
gto19's Avatar
it looks to me that wiper motor was made on march 20 1970.that would be the 79th day of 1970.
where is the date code stamped on the wiper motor?
http://www.flicklives.com/Timeline/1970_cal.html
Old 07-12-2005, 08:01 PM
Held for Ransom's Avatar
gto19, here is a picture. This code might be considered correct for a 1970 02B car, as it is on my 02A car.
So long, farewell.
Old 07-13-2005, 06:09 AM
gto19's Avatar
held for ransom
how would you read that?
damn i wish i had your knowledge!
thanks alot dude
Old 07-13-2005, 04:16 PM
Top line, number is the part number. Second line, first set of numbers is the day code (353th (Dec. 19), in this case) second number is the year (1969, in this case). The rest are probably shift designations and such.
So long, farewell.
Old 07-13-2005, 05:26 PM
gto19's Avatar
cool
i looked at mine and it has this.its also a silverish color.
258 9 2a
my car is 70 goat
10-c-69
Old 07-15-2005, 03:54 AM
Racerboy -
Your car was produced in the 2nd week of April (1970) which would be anywhere from the Julian Date of 98-104
This wiper motor is julian date 79! It can't get much closer than that for you! The wiper motor was made anywhere from 19-25 days before your car was assembled!
Let me know if interested. I'm in NJ too. I am literally leaving in an hour to go to Peru for a 12 days (come back the 26th) so don't mind if I don't get back to this board for awhile.
You can email me at [email protected] and I may have email access down there. If not, and I can't get back on the PY board, then I'll check back in on the 26th.
Old 08-05-2005, 01:31 AM
70ra455's Avatar
70ra455 70ra455 is offline
Default I'm back
Hi Racer
Just wanted to know if you were interested in the wiper motor. If not I'll just pack it away for another day!
Phil
