Old 05-08-2005, 09:08 AM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
Does anyone happen to know that RPM range in a stock torque converter from a th-400 ?
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-13-2005, 08:15 AM
frbird400's Avatar
frbird400 frbird400 is offline
I ran a B&M Holeshot 2400 for years w/ a mild 400 buildup. Great street manners. I'm not sure about the B&M Tork-Master, never used one.
Old 05-09-2005, 09:42 PM
thats horribly low im thinking of going to a B&M TORK MASTER 2400, will these be good in a 400 engine, 1 3/4 super comp. headers, performer Intake, and holley 750cfm, and a .490" lift lunati?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-12-2005, 09:07 PM
that 13" is a 3200 stall?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-09-2005, 10:08 PM
really? damn im bidding on one, i was thinking it would be good since im not pumping out so much HP and TORQuE,
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-12-2005, 09:09 PM
bob, i sent u a private message
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-10-2005, 07:01 AM
ok now im scared about this purchase on a 2400 it seems many people have their own opinion as for the 3200 thats seems incredibly high doesnt anyone agree?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-09-2005, 10:03 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
i wouldnt waste my money on a b&m converter. I installed a 2400 stall TCI piece of junk and it didnt feel any different than stock.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 05-10-2005, 09:05 AM
grandville455's Avatar
It All depends what your total combo is and what you want to do with it...if your just streeting it and maybe a race now and then then u dont need a big stall like me...,but i want every possible hundreth i can find thats why i went to this ... The guys that run these cont 10" will all atest to how tight they are ,before i had a cont 13" stalled about 22-2400...it was awesome also!....
Darby
M/T 275/60 ET SS Drag Radial
Old 05-10-2005, 02:44 AM
sardegna sardegna is offline
i have a 23-2500 converter, which is borderline too high for the street. i'll probably go to something around 2000 rpm when i have the tranny rebuilt next month.
406, 4X, balanced rotating assy, forged pistons, Crane 272, Torker 2, Street Avenger 770, 3.73 posi disk brakes
Old 05-13-2005, 03:21 PM
you seem to have a good set up and all you got was 13.50's damn i should get ready to spend a lot of money.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-12-2005, 08:44 PM
78T/A462 78T/A462 is offline
I run a 3800 10 inch converter on the street. Of course I don't get in stop in go traffic. Ive had this loose converter for 4 years with no problems. It's a transking 10p. I wouldn't worry about running a tight 3200 like the continental. I know people running 9inch converters on the street with no problems. I guess it depends on your preference. Sound like the 3200 continental would be a good choice for you. Good luck!
Old 05-10-2005, 05:19 AM
A conv built right will be tight on the street still!I use a 10 " 3200 stall from cont, And I drive on the street and race my car at the track all year! ....it drives like a stock one till you nail it..yes it is looser than a stock one ,but if u have used stall conv before you will know that these are very tight! You get what u pay for buy a cheap one now and down the rd probably be rebuilding your tranny besides looking for a new conv...JMO
Darby
Old 05-12-2005, 07:21 PM
whats the stall and how much?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-12-2005, 08:33 PM
Jim Moshier's Avatar
Bob,
If Osvaldo isn't interested in the 13in Continental, I am .......let me know what you want for it.
Jim
Jim Moshier
1962 Catalina 389
Old 05-12-2005, 08:39 PM
general general is offline
Drop me a line at the above email address if you would. Thanks, Bob
Old 05-08-2005, 10:02 AM
76TA428 76TA428 is offline
1300-1600 I think.
1979 Trans Am
1969 428
Old 05-12-2005, 09:34 PM
frbird400's Avatar
I run a tight 8" cont. converter. It is fine on the street from stoplights. Slow acceleration and it doesn't stall too high, romp on it and you get 4K rpms quick.
Old 05-12-2005, 10:15 PM
wellim at a stock level engine and i bought a turbo 400 off someone and recommends a 2500 stall. the trans was rebuilt and has a transgo shift kit and a deep pan. and the best thing about it was that i only payed $81.00. is a 8" compatible with a stock engine?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
