Old 03-23-2003, 07:37 PM
rascal455ho rascal455ho is offline
What is your fastest time with a hydraulic cam?
Old 03-27-2003, 06:23 PM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
WOW more and more guys from the DFW poping up! nice times weak64. Was that at kennadale? sounds about like my 455, TRW's and 62's.
http://home.earthlink.net/~saawatson/ my 1983 trans am. PONTIAC POWERED
Old 03-24-2003, 06:47 PM
Torment's Avatar
Torment Torment is offline
About a decade ago 4 yr old motor 11.9 @ 113mph in 100deg humid WI cheesehead weather with a Crane 290/300, 455ci, 6X-4, Torker, 850dp, HEI, 3.90's, and a Switch Pitch trans. Drove 150 miles to the track one way, 3800lbs.
The secret to happiness is not getting what you want but rather, wanting what you have.
Old 03-24-2003, 05:51 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
11.92 3400# 78 T/A 455 cast everything, street ported 670's, RPM, 800 Holley, 4.10's 29" tires, T-400 2500 Fairbanks conv. Shifted at 5200. Lunati Street Master #07703 [email protected] .534 lift 108 LSA. 4500 ft above sea level.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-24-2003, 05:52 AM
Rob B's Avatar
Rob B Rob B is offline
Best of 11.65 @ 114 and an average 11.80's for almost 16 yrs using the same cam and lifters.
Comp Cam 305 magnum in a 455 with oddball d-ports, 28" DOT tires and mufflers, 4:10 gear wieghing around 3400lbs. (the cam still is in great shape!) street driven
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 03-31-2003, 04:40 PM
TA_Thomas's Avatar
TA_Thomas TA_Thomas is offline
72 TA w/462 Edelbrock heads, stock manifold 226/234 @ .050, drag radials, Cal Tracs
12.63 at 107mph
72 Trans AM HO
Old 03-23-2003, 09:03 PM
So far 13.50@99MPH, but made Lots of changes that dropped my 60' times and increased my MPH, so i redid all the stuff that killed the 60' times and left the MPH stuff alone, so hopefully now i will go faster :P looking for 12.90s-13.00. No Nitrous here yet will do that after i hit the 12s :P
Mike
Old 03-23-2003, 08:32 PM
Old Man Taylor's Avatar
10.80 at 129.31, but that was with nitrous. That is my streetcar.
http://www.jimspontiac.homestead.com/Index.html
Old 03-24-2003, 06:28 PM
judgera4's Avatar
judgera4 judgera4 is offline
70 Firebird 11.54 @ 116 Ultradyne Hyd 455
69 GTO JUDGE 12.17@ 114 Ultradyne Hyd 400 RAIV
1969 GTO Judge RA IV 4 Speed Windward Blue
1967 Firebird 428 auto
1970 Firebird 455 auto
1998 Trans Am WS6
2005 GTO M6
Old 03-30-2003, 01:41 PM
Floyd Hand Floyd Hand is offline
Weak64,
Now I know your ID. Hurry and finish the new one and come join us again.
Old 03-23-2003, 10:29 PM
Bartman Bartman is offline
12.30@111mph '78 FB, 3980lb, 3.73, T-350, stock converter, 462, 750 Q-jet, 296H comp cam, with regular 275/60 radials and deep staged. I'm pretty sure I could drop .5 with a converter and tire change.
Bartman
Ponies run but Birds fly
Old 03-24-2003, 12:17 AM
Don't worry John I'll get that 10 sec pass out of your old flat tappet cam for you! one of these days at least
Old 03-23-2003, 11:58 PM
SLOW 77 SLOW 77 is offline
[email protected] 7.24 in the eighth on that run; Ultradyne 239/247 with Rhodes Lifters, 474 87cc Eheads, pump gas 3650# 3.42 gears. Ran a best of 7.10 in the eighth mile with this cam, so that should have been an 11.10-11.15 full pass. I wanted a 10 second slip but it was not to be with that combo
Old 03-23-2003, 10:02 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
11.53 Ultradyne .231/.239 3250lbs 28" slick 4.30's with a glide, ported 16's RPM 850 Holley.
Old 03-26-2003, 05:23 PM
LilJack- any tid bits to share as to carb & cam specs ?
'Damn right it's a street car'
Old information here:
Old 03-23-2003, 10:06 PM
dammen8's Avatar
dammen8 dammen8 is offline
My firebird @ 3800lbs race weight with a .030 over 428 ran 12.08@109 with 4.33's and 28X12.50 street et's. I ran this combination back and forth to work and raced it for 7 years, I never touched a thing.
Chad Dammen
ND's fastest Pontiac (I think) and Minot's fastest street car (not like that means much)
3500lb 10.5" tire. [email protected] with a poor 60'
Old 03-23-2003, 09:17 PM
Gooatee's Avatar
Gooatee Gooatee is offline
12.20 @ 109 mph on DOT slicks and through the exhaust. Car weighs 3870 with driver and has seen plenty of trips up and down the road! That is with a mild 400 motor.
Old 03-23-2003, 10:10 PM
slowbird's Avatar
slowbird slowbird is offline
11.88 at 113 with a very streetable 406. 12.64 at 107 with a 400 (tow car). And 10.14 at 129 but that is a more of a racecar than a streetcar.
75bird 7.41 1/8mile at 92mph street car
73Ventura 11.88 at 113 streetcar
69GrandPrix 12.64 at 107 tow car
65GTO 10.14 at 129 tri-power dragcar
Old 03-30-2003, 09:09 AM
PROBRD PROBRD is offline
10.83 @ 124 with a 6.87 in the 1/8th with a Comp Cams Magnum 305 in a 455. Car weighs 3345. Ran a best of 6.76 in the 1/8th in real good weather. I haven't driven it on the street for a few years but it does have a hydraulic cam.
440:
1/8th mile 6.56 @ 104
1/4 mile 10.43 @ 127
400:
1/8 mile 6.86 @ 99
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
