Old 05-21-2003, 01:52 PM
dh_gto dh_gto is offline
I just went to the track over the weekend and here is what I ran in a 4-speed 67 GTO in full street trim, full tank of gas, street tires, through the mufflers. Track is at 2700 ft and there was a headwind of 5-10.
1st run
R/T: .833
60': 2.466
1/4: 13.169
MPH: 112.62
2nd run
R/T: .686
60': 2.276
1/4: 13.033
MPH: 110.83
What do you think my car is capable of with some traction and a little practice driving?
1st run
R/T: .833
60': 2.466
1/4: 13.169
MPH: 112.62
2nd run
R/T: .686
60': 2.276
1/4: 13.033
MPH: 110.83
Old 05-21-2003, 02:15 PM
Larry Navarro's Avatar
with that MPH....looks like low 12's.
1973 SD455 T/A
1979 S.E. T/A
http://community.webshots.com/album/16587603rOyvmFCiHs
Old 05-21-2003, 06:46 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I'm curious to know more about your engine combo. I ran a 4-speed tri-power '66 GTO with a 455 (essentially stock) at the track here in Tucson (3075 ft.) and had 60 ft. times as low as 1.95, but never ran faster than 101 or quicker than about 13.80. I assume traction must be a big issue for you when I compare your 60 ft. times to your 1/4 mile E.T.'s and speeds.
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 05-21-2003, 06:51 PM
Yeah no kidding im putting down 1.83 60' times and running 13.27@101 mph, what kinda combo you got? i have never been able to get over 101 mph
Mike
Old 05-26-2003, 01:27 AM
Sorry for the delay on responding about my combo but here it is.
Engine:
JBP shortblock kit (461) assembled at home with the following parts:
-400 block
-4.25" stroke crank
-Eagle 6.8" BB chevy rods
-Ross dished pistons w/ Total Seal conventional rings.
-Edelbrock 72cc heads
-Ultradyne hydraulic 247/247 @ .050, .530 lift.
-Torker II intake w/ 850 demon carb.
-Dougs headers
I don't know how much the car weighs, but it is more or less stock except for I am running HO racing lowering springs and front/rear sway bars and 255/50-16 BFG's in back and 225/50-16 up front. Rear end gearing is 3.70.
Old 05-26-2003, 09:52 AM
E-Heads and bigger cam.
That is why you are faster :P
Definatley low 12s with some traction and practice.
Mike
Old 05-28-2003, 03:58 PM
GONZO's Avatar
GONZO GONZO is offline
1st run
R/T: .833
60': 2.466
1/4: 13.169
MPH: 112.62
WOW, almost unbelieveable?
A 2.466 lousy 60ft time...no traction at all
combined with
A 112.62 MPH at only 13.1's??
you got yourself a hell of a midrange there!
With those MPH's you should be low 12's easy.
Get some tires.
http://www.kingofgtos.com/index.htm
http://www.stockappearingdrags.com
Come on get off that lawn chair and drive that car like it was meant to be driven.
69' 400 RAIV Judge Conv... 12.86@107 Factory Stock
69' 400 RAIV Trans AM .....12.48@110 Factory Stock
69' 400 RAIV Judge HT..... 13.07@104 Factory Stock
73' 455 SD Trans AM........13's?? not run yet
66' 455 GTO Convert.........12.20@112 non original
63' 421 SD Catalina...........restored fast as h*ll
Old 05-28-2003, 07:00 PM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
See below...sorry..
http://www.dannys65gto.com
http://kurtspontiac.homestead.com/dannys65gto.html
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Goathead's Avatar
Get some tires.
I know that feeling...went to the track Sunday, the rim's with the ET Streets would not fits (rubbed the disc brakes) so I had to run with BF Goodrich street tires.
R/T 6.1 (Not bad for my first pass in 32 years and a pro tree)
60' 2.242
1/4 13.30
MPH 107
Bought some ney Weld Wheels and mounted the M/T Streets on them yesterday, so the next trip should be much better....
