Old 04-26-2004, 04:53 PM
lazycat lazycat is offline
When the headlights close on my 95 Firebird they make a grinding sound for app. 7 seconds then it quits. Is there an adjustment to the lights ora relay that is bad?
Old 04-27-2004, 02:04 PM
rainmaker612 rainmaker612 is offline
I read somewhere that there are plastic gears that go bad and it will start making that noise.
check out this place for replacement.
http://www.rodneydickman.com/n113.html
Old 04-28-2004, 05:25 AM
Thank-you for the information.
Old 05-05-2004, 09:58 AM
quicksilver97ta's Avatar
For a quick fix, albeit temporary, You can disconect the linkage from the motor, spin the motor 180*, then reattach linkage. This uses the opposite side of the gear where the travel stops which is what wears out the gear.
I did this in '99 on mine and so far so good. Its no longer a daily driver but it does get used (and slightly abused, no trailor queen here). I also pull the rubber covers off the manual knobs and spray some lube in the motors occasionally.
Old 05-12-2004, 07:00 PM
6t7goat 6t7goat is offline
I had the same thing happen to my 95 T/A. I took the motor apart and turn the gear and put it all back together. Never had another problem with it.
