Old 02-19-2004, 10:14 PM
thefirebirdm@n's Avatar
thefirebirdm@n thefirebirdm@n is offline
Send a message via MSN to thefirebirdm@n
HELP!! Went outside last night to take some pics of the TA. Wanted to shoot some pics of the empty engine compartment and I can't get the hood open!!
When I pull the release the hood springs up and stops on something hard. I thought maybe I wasn't pulling the release far enough to pull the little latch all the way in but I worked on it for an hour. I tried pulling the release to pop the hood up, then slightly push the hood down and hold, then pull the release again and lift the hood up again but no dice.
I also tried leveraging the hood to the left or right hoping to pop it off the latch but that didn't work either. I was so mad after an hour of this I was ready to go rent a torch.
I also tried spraying lithium grease in and around the latch as much as I could but it was hard to do since the hood was only partially open!! Release works a little easier but I still can't get the hood up.
The hood is too rusty to save anyway. Any suggestions???
Jimmy
www.firebirdgallery.com
2002 WS6 M6 Trans Am
1970 RAIII Trans Am
1969 GTO
"If you own a Firebird, I'm interested in putting it on my site!!!"
Jimmy
2002 WS6 M6 Trans Am - original owner
1973 Trans Am 455/4-speed
1971 Formula 400/400
1969 GTO 400/400 - 3rd owner
1968 Firebird Convertible 350/200R4
POCI - AAC
Jimmy
1970 RAIII Trans Am
1969 GTO
Jimmy
POCI - AAC
Old 02-19-2004, 11:08 PM
78 GHOST 78 GHOST is offline
Jimmy, the T/A I have is really sensitive to improperly adjusted hood alignment. I adjusted it once to get the gaps more even and almost couldn't get the hood open.
To your question, I would suggest trying to push the hood with your hand toward the rear of the car. You also did what I would have tried in pushing from side to side. If this doesn't work, try having a friend (or 2) push the hood towards the front of the car while you try to release it.
Don't worry, this is just like that damned Rubic's cube, just gotta find the right combo.
-Matt
____________________________________
Much love out to my Peeps
"I work in high speed aluminum tubing."
Old 02-20-2004, 12:00 PM
1970cat's Avatar
1970cat 1970cat is offline
if the engine compartment is empty , i am guessing that there is no radiator either. if this is the case you might want to jack the car up and crawl underneath it with a flashlight. have a helper work the latch while you observe with the flashlight what the problem is.
Old 02-22-2004, 11:27 AM
Yes the radiator is removed too. I actually did get into the engine compartment. I got through the hole in the hood for the shaker scoop. Once I was in there I took a flashlight and looked around but the hood is too far down on the release latch to see whats going on. I couldn't see anything more than when I was outside the car. I did try pushing the release lever with a screwdriver right at the joint at the base of the release latch but it didn't change anything.
I will try pushing it forward and backward. I did not think of that. Thanks!!!!
Jimmy
1970 RAIII Trans Am
1969 GTO
Jimmy
POCI - AAC
Old 02-24-2004, 10:05 PM
Gordy Doyle Gordy Doyle is offline
Was there anything blocking it on or near the core support when the hood was last closed?
Gordy
Gordy
73PF455TH4003.08:1
Old 02-27-2004, 08:45 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Was there anything blocking it on or near the core support when the hood was last closed? <HR></BLOCKQUOTE>
No, I had the hood off the car for a long time as well as the hood hinges. We moved and I had to transport the car to the new house so I bolted the hood hinges and hood back on and thwn when I went to try and open it is when I found it wasn't going to open again. I'm sure thats what caused it.
Jimmy
1970 RAIII Trans Am
1969 GTO
Jimmy
POCI - AAC
Old 03-01-2004, 02:19 PM
yankeeralph yankeeralph is offline
Have the same problem with my 78T/A. Almost like a safety catch. I just lightly push down on the hood and pull the hood latch handle again, then pull up lightly on the hood. It really is a hood latch alignment problem but mine is so straight that I do not want to chance another realignment. Hope this helps!
Old 03-02-2004, 07:52 PM
superdutydave's Avatar
superdutydave superdutydave is offline
There remains one distant and remote possibility-Ur an idiot
Old 03-02-2004, 09:00 PM
70lemanscov's Avatar
70lemanscov 70lemanscov is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by thefirebirdm@n:
I actually did get into the engine compartment. I got through the hole in the hood for the shaker scoop. <HR></BLOCKQUOTE>
and skinny too
Old 03-02-2004, 10:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> There remains one distant and remote possibility-Ur an idiot <HR></BLOCKQUOTE>
Is that supposed to be funny? This is a real problem and apparently I'm not the only one whos had to deal with it. If you don't have anything constructive to add, don't bother jerk
Jimmy
1970 RAIII Trans Am
1969 GTO
Jimmy
POCI - AAC
Old 03-02-2004, 11:00 PM
Jimmy, try jacking the front end up so you can get to the latch from below and try to cycle the lock mechanism.
Old 03-11-2004, 09:51 AM
b Thanks for all the help guys. I pulled hard on the front right corner while a buddy worked the catch and it finally popped off the latch!!
Jimmy
POCI - AAC
Old 03-11-2004, 04:42 PM
dwainm dwainm is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by beetlejoose:
There remains one distant and remote possibility-Ur an idiot <HR></BLOCKQUOTE>Ur a dork.
It's Injun Joe, the Superchief, woo woo!
