Old 10-08-2004, 09:10 PM
Cliff R's Avatar
Cliff R Cliff R is offline
The RPM q-jet was carefully recalibrated and prior to testing. The APT can be used to fine tune part throttle mixtures, it is a really nice feature. The power piston spring(s) are not really much of a factor when tuning a q-jet. Use the strongest spring that will have the power piston stay down at idle....Cliff
