Old 02-07-2004, 04:11 PM
Lobito's65Cat Lobito's65Cat is offline
Hello guys, and sorry for the dumb question, i took my starter out a few days ago to go and get a new one , now that i got it i dont remember where hte extra wires went, i know the battery goes to the middle terminal but i got two more wires a black one and a red. Do they go on to the S terminal or the R terminal? Thanks
Old 02-08-2004, 11:27 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
The 'S' terminal is for Solenoid and the ignition switch wire goes on that. The 'R' is for relay and that usually goes to send full 12 volts to the coil during cranking. Usually there is a purple wire on the 'S' terminal, and usually there is a red wire with a bigger end on it that goes on the large post with the battery cable to supply main power to the car accessories. Not all cars use the 'R' terminal. Is it possible the black wire is really a dirty purple?
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 02-09-2004, 08:05 PM
Yup! Got it running now! Thanks so much for your help!!!
