Old 11-18-2004, 05:18 PM
Gary S. Gary S. is offline
And start with the basics,please-like,just what all does the thing DO,anyway?
Old 11-18-2004, 05:56 PM
David Jones's Avatar
It all depends on about a jillion different variables. Motor, rear gear, car weight, purpose of the car etc. I just put a 13" from Dynamic Converter in my car. 400ci with a little more than a Ram Air III cam, Turbo 400 and 3.55 gears. It makes plenty of power down low so I don't need a high stall speed converter. I also don't drag race. The best thing you can do is call a major mfg and tell them what you have and what you'd like to do with it. Thats what they are there for. Coan, Continental, Dynamic, B&M, TCI all have web sites with general guidelines and there is a ton of info in the archives here and all over the web.
Click here for torque converter info
Old 11-18-2004, 06:00 PM
Thanks David.
Old 11-18-2004, 06:32 PM
Gary, call Kris at Continental Converters (310) 674-1072.
They custom-build them for every application. Probably the best converters for a street-strip Pontiac. Having the right converter can make a HUGE difference in performance and driveability. Continental doesn't use any cheap internal parts, they last.
Just bought my third one from them, I can't wait to put it in my car. Not cheap, but you get what you pay for.
Old 11-18-2004, 11:16 PM
screamingchief's Avatar
torque converter is a hydraulic fluid coupling device (think clutch) that has the ability to multiply torque up to a specific rpm, depends on many factors the amount of multiplication,slip,stall etc. The inside is made of four basic components the two halves(rotors), a stator, and a sprag,basically think of a fan blowing on another fan one larger one smaller with a shaft on it, big fan makes little one spin harder until sprag locks up (theroretically). For street use you generally would want cruise rpm higher than adv. stall speed to avoid excessive slippage and heat buildup (use a trans cooler w/higher than stock converter)
This space for rent...
Old 11-19-2004, 05:55 AM
Thanks chief-that was a good explanation.
Old 11-19-2004, 07:33 AM
68lemans462's Avatar
68lemans462 68lemans462 is offline
ditto on the continental. Very quality piece. b-man, you have the coolest avatar on this earth...
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 11-19-2004, 07:35 AM
grandville455's Avatar
My continental 3200 flat out rocks!!!!!
Darby
M/T 275/60 ET SS Drag Radial
Old 11-19-2004, 11:59 AM
Ron Landis's Avatar
Manufacturers rule of thumb is 400 to 600 rpm above where the cam comes in. This works ok for street/strip applications, race units need more serious consideration involving more parameters.
Old 11-20-2004, 05:00 PM
louisville97 louisville97 is offline
B-Man,,,
That is a very amusing avatar. One of the funniest I've seen yet. Quite deceiving at first, but hilarious nevertheless.
Old 11-20-2004, 06:00 PM
loren loren is offline
What is the approximate price on the continenal converters I'm looking for a 2800 stall Thanks Loren
Old 11-20-2004, 08:17 PM
Tight 10 is $575 I believe
Darby
Old 11-21-2004, 12:53 AM
Thanks grandville did you go with a another brand seen you sold a continental. Loren
