Old 03-28-2004, 11:37 AM
Thordog Thordog is offline
For all you sick minds out there, I do mean the dipstick on my 65 GTO.
The motor was just rebuilt last year, which I thought might correct this issue, but every time I push it down, it pops right back up when I start it.
Thanks in advance!
'65 GTO Conv't
Top down, radio off.
Mechanical music!
Thanks in advance!
'65 GTO Conv't
Mechanical music!
Old 03-28-2004, 12:42 PM
gto65lvr's Avatar
gto65lvr gto65lvr is offline
I may have a dumb question but did you remember to put the lower dip stick tube in that bolts to the main cap?
crank/rods may be hitting the dip stick is the end of the dip stick, inside the motor, look damaged in any way?
Eric
CURRENT CARS
68 Firbird 400ci convertible
Old 03-28-2004, 12:54 PM
Andre's Avatar
Andre Andre is offline
Do you have at least one vent on one of your valve covers. If not, the motor is trying to vent out of the dipstick tube.
Old 03-28-2004, 09:36 PM
Mike Moore Mike Moore is offline
Try turning the dipstick 180 degrees, the end may be hitting the crank..... it worked for me.
Mike
Old 03-31-2004, 07:41 AM
also be surethe pcv valve is working properly.
mike
former." --Albert Einstein
- Winston Churchill
Old 03-31-2004, 09:48 AM
Pecosbill's Avatar
That's NITROUS OXIDE that you're supposed to be putting into the engine, not SILDENAFIL CITRATE!(That's Viagra for all you younger guys) Hey, I couldn't resist.
Pecosbill
Old 04-01-2004, 08:23 PM
MPKind's Avatar
MPKind MPKind is offline
Yeah, lower dipstick tube...is it in place? Had a 389 without one, and it just beat up the stick.
Old 04-01-2004, 09:34 PM
Thanks for the input.
I will try out your ideas this weekend.
Thanks again,
Thordog
'65 GTO Conv't
Mechanical music!
Old 04-02-2004, 04:16 PM
Trips4me's Avatar
Trips4me Trips4me is offline
Send a message via MSN to Trips4me
Mine 389 does the same thing but only when the engine gets over about 2500 rpm.. Weird.. I thought it must be vibration. I'll try to turn it around and see if that works. I know the lower tube is in because I put it in and the PVC valve is good.
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's
Old 04-02-2004, 07:13 PM
Tom Wood 64 Tom Wood 64 is offline
Mine does the same thing. I believe there should be a rubber grommet in the ring on the dipstick that goes over the tube, which mine is missing. Anybody agree?
Old 04-03-2004, 05:59 PM
DINO1's Avatar
DINO1 DINO1 is offline
On my 64 the dipstick has a section on the top that is sorta like a "Y" and I took a screwdrive and spread it apart and it fit a little more snug in the dipstick tube and stopped popping out. I took this advise from my wife as she is an expert on dipsticks popping out.
Old 04-08-2004, 10:24 AM
Trips4me's Avatar
I turned mine 180 and it has stayed put since then... man, if all repairs/problems were that easy to fix I'd be in heaven.... and bored!!
Good call, Mike!!
Old 04-08-2004, 08:27 PM
Tigerpaw65 Tigerpaw65 is offline
I to have a 65 389 with the dip stick popping up.All parts of the tube are in place. So your turning the dip stick around, which way are you placing the finger ring? I've tried both ways. Motor was rebuilt in 2000 and has 5000 miles on it now.
Thanks,
Brian
Tigerpaw65
Old 04-09-2004, 06:35 AM
Trips4me's Avatar
Mine is a 1965 389 also rebuilt last September... the DS was popping out all the time until I turned it in this direction... photo attached.
Old 04-09-2004, 01:34 PM
Rick Rosen's Avatar
Rick Rosen Rick Rosen is offline
mine edges up a bit.....I'd say maby 1/8 - 1/4" on each run around town. It's never a problem, I just push it back down everytime I pop the hood....which is quite a bit....(love to show it off if you know what I mean).
Old 04-15-2004, 06:49 PM
Hey Trips!
I flipped it around and to my surprise it stayed in the tube!
Thanks for the good advice.
Thordog
'65 GTO Conv't
Mechanical music!
Old 04-19-2004, 06:29 AM
Trips4me's Avatar
You're welcome Thordog but it was actually Mike's idea.....all did was post the photo that showed which direction I turned it. Thanks Mike!! Jim
Old 04-19-2004, 08:06 PM
64vert's Avatar
64vert 64vert is offline
Yes! Thanks to DINO1 for the screwdriver trick, and Mike and Trips4me for the proper orientation. My dipstick is now staying put!
Dick
Old 01-14-2007, 10:37 PM
gtopont gtopont is offline
Default dip stick popping out on 65 gto 389
I bought my 65 gto NEW and it allways popped out and every 65 gto I've seen...unless you put in backwoods !!
