Old 08-29-2003, 09:22 PM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
I just finished the engine and am looking for some criticism on it...Does it look O.K? What looks bad and what would you change...trying to get it as nce as possible...
Thanks!!!
Brad
Take a ride in my Twin Turbo 63 Lemans.......
http://www.youtube.com/watch?v=Ad8g9IfWxKI
Hot Rod Cover Car -April '07
PHR Magazine Sept.'08
1244HP Pump Gas Dyno @ 11psi (32PSI MAX)
http://s297.photobucket.com/albums/m...ipumpgas-2.flv
Thanks!!!
Brad
Old 08-29-2003, 09:23 PM
and another....
Old 08-29-2003, 09:24 PM
Another one
Old 08-29-2003, 09:25 PM
Front side....
Old 08-29-2003, 09:26 PM
And my STEALTH MSD firewall mounted box...most people miss it!!!!
Old 08-29-2003, 09:58 PM
goatseeker's Avatar
goatseeker goatseeker is offline
Boy, hard to criticize something as clean as that!
Looks nice, but how does she run!?
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
Old 08-29-2003, 10:09 PM
What's not to like?
Some say the glass is half full, others say the glass is half empty...I say 'Are you gonna drink that?'
www.outlawpontiacs.com/members/B-Man2.php
www.outlawpontiacs.com/members/B-Man.php
Old 08-30-2003, 10:31 AM
Rugratman's Avatar
Rugratman Rugratman is offline
Damn, Brad no wonder it's taking so long to finish.
Looks awesome.
Are you going for the stock look ?
You have a stroker in her right ?
Beware of those mud puddles
........I'm just learning as I go.......
Old 08-30-2003, 10:37 AM
Thanks!!! Yea, it's a stoker!!! I was going stock look but some things I had to change....the intake, carb, radiator and exhaust is not original..It's running as it should now and I'm still working on the dash.....
Brad
Old 08-30-2003, 01:16 PM
Rugratman's Avatar
What kind of radiator did you use ?
did you build your stroker ?
Old 08-30-2003, 03:03 PM
Bill H's Avatar
Bill H Bill H is offline
Engine looks great , I just have one question. Why do you have two oil fill caps, one on each valve cover? You need to fire that puppy up and burn off some paint,it's too clean
67 GTO HT
1968 400 Engine YE
TH-400
#13 Heads -J069
Q'Jet .
8.2 Eaton Posi/3:55
Old 08-30-2003, 06:22 PM
The 2 breathers sort of balanced the engine I thought and it puts out 613hp, so some extra breathing room only helps....I don't like the way the spacers look to much but I had to clear the rollers, still looks more "stock" than the aftermarkets I thought....
Brad
Old 08-30-2003, 06:25 PM
Radiator is a Rodney Red - Highly recommend!! Yes, I built the engine myself but didn't do the heads or balancing and machine work...left that to the guys with the good tools!!
Brad
Old 08-30-2003, 06:37 PM
ucmaddoc ucmaddoc is offline
Hey Bill,
Take the air cleaner off and give us a shot of the carb and from the rear if possible. It looks great!
Old 08-30-2003, 06:41 PM
ontheblocks ontheblocks is offline
That's a sweet looking engine! If it was mine, I would look at finding/fabricating a different throttle cable bracket, it was the only thing that stuck out, on an otherwise outstanding job!
Do you have any sound recordings?? Would love to hear it run!
If it has ti*s or tires, it's gonna cost ya!
Old 09-01-2003, 06:08 AM
6t7goat 6t7goat is offline
Awsome!!! I'd be proud of That motor. Do those valve cover spacers seal well? It would suck to have oil leaking on that fine lookin engine.
Old 09-01-2003, 07:29 AM
So far the seals work well, no leaks!! The gaskets are Felpro "rubber cork" and they come out too far but I didn't want to cut them, later I might use tube sealant to hide it better....
Thanks for all the input, I'll need to work on the bracket..
Brad
Old 09-01-2003, 07:37 AM
myoldgoat myoldgoat is offline
Looks great....Can you paint the spacers so same color as the block to hide em and trim the gasket may make it harder to tell. If your not going for completely stock look how about a one wire alternator so you can get rid of the voltage regualtor and some under hood wireing. Really looks nice wish mine looked that good.
Old 09-01-2003, 05:57 PM
vidguy's Avatar
vidguy vidguy is offline
.......awesome...... no criticisms here...!!!
James Fasso
[email protected]
'67 GTO Conv
"I told my parents I wanted to be a comedian
-But they just laughed at me"
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
