Old 05-14-2004, 08:16 AM
Fred's red sled's Avatar
Fred's red sled Fred's red sled is offline
Hi guys,
My 66 GTO power steering pump has a slow leak and does not operate at low RPM's. Question is: do I need a new pump, or is there a rebuild kit, or do I just need a new seal somewhere?
I want the quickest, easiest and best fix. I'd rather not commit myself to a long project...
Thanks, Fred
"Come on baby... Sit back, relax and enjoy the ride!"
Hi guys,
Thanks, Fred
Old 05-14-2004, 08:27 AM
vidguy's Avatar
vidguy vidguy is offline
I rebuilt mine a number of years back. Since I dont remember the details, it couldnt have been very hard.. I'm not an expert mechanic..
I do recall something about the nut on the front being a strange shape and being a little hard to deal with...But once I had it open I think it was pretty simple. I think I bought the rebuild kit at napa, wasn't costly at all. And it solved my leaks..Hoses cost way more then that.. MIght check those first.. to be sure.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 05-14-2004, 08:48 AM
67blackdiamond 67blackdiamond is offline
This is a true "quick fix". Most purest will not agree with me but I am not one, just a person that drives MY 67 GTO around 10,000 a year and loves it. I just went to Pep-Boys and bought a rebuilt. It is the EXACT same one that was on my car and it has worked fine for years. Comes with a guarentee but has a core charge. Just hang on to yours and rebuild it at leasure. Put yours back in an resll the other. Very quick fix and I believe they are around $35. I find it a lot easier to rebuild something when I want to and not when I have to. Get out and enjoy the weather!
Old 05-14-2004, 09:05 AM
Oh, as I recall, there was nothing unsual about the nut but there is a locking type peice directly behind the nut, as part of the pulley, that you will have to hold to loosen the outer nut. I think it is real tight behind the nut and it may be hard to get a standard thick wrench in there. I think I had to grind some of the meat off mine to fit in there[?]. The very first thing I did was loosen the nut, then removed the pump. It may help a little if you leave the belts on until you loosen the nut to give a little more tention.
Old 05-14-2004, 09:06 AM
Black Diamond,
Did you buy a rebuilt pump AND a rebuild kit then? Interesting...
Old 05-14-2004, 11:34 AM
engineer engineer is offline
impact gun removes pulley nut. use the same to tighten.
