Old 05-16-2004, 12:59 PM
71lemanssprt's Avatar
71lemanssprt 71lemanssprt is offline
WHAT DO I DO WITH THE WIRE THAT HAVE RUN TO THE COIL IF I SWITCH TO HEI mainly the yellow wire which seams to energize the starter solenoid and can I use the black positive wire to power the HEI system.thks matthew
Old 05-16-2004, 03:12 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
To switch to HEI you need to run a new positive wire from a full 12 volt source, as the original wire is a resistor wire and only has like 9 volts. I have heard of people using the resistor wire to power a relay to give the hei the full 12 volts. You can just cap off the yellow wire from the starter, you dont need it anymore(it was used to send a full 12 volts to the distributor during cranking).
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 05-17-2004, 11:26 AM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Somebody mention before that there is a spare switched 12 v position/connector in the fuse box in the 70+ Pontiacs u can use. I would check that out first before wiring in a relay and separate power.
