Old 10-13-2004, 04:23 AM
troy_barker's Avatar
troy_barker troy_barker is offline
Where can I get 18 gauge steel. I have looked in welding shops, Home Depot, Lowes. All I can find is 16/14/20/22 etc....
That is the correct thickness for auto body panels.......isn't it?
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
previously owned
78 Firebird
67 Nova
64 Nova
Old 10-13-2004, 04:50 AM
69goatboy's Avatar
69goatboy 69goatboy is offline
I would prowl around the weld shops more or maybe try some machine shops. If they do not have any scrap, they should at least be able to order you some or point you in the right direction. 18 ga. should not be that hard to find, we use a ton of it in our shop (we're a medium sized machine shop).
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 10-13-2004, 06:54 AM
Judas Judas is offline
Also check ventilation and siding companies. I got mine from York Corrugating, who mostly supply ventilation contractors. They wanted to give me galvanized, but I asked for cold-rolled as I was going to have to weld it.
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
Old 10-13-2004, 06:55 AM
Almost forgot, the corrugating Co. was 1/4 the price of a steel supply shop. Go figure...
Old 10-13-2004, 08:19 AM
Thanks I will go look at these sources
Troy
previously owned
78 Firebird
67 Nova
64 Nova
Old 10-13-2004, 08:55 AM
louisville97 louisville97 is offline
Troy,
18g is a little thick for general body work isn't it? It is pretty thick for trying to bend around different curves and contours. I prefer 20g for body and 18 for more structural body fabs such as trunk supports and body bracing.
Old 10-13-2004, 09:36 AM
Mr. Bruce has a point. I bought a sheet of 20 gauge myself.
Old 10-16-2004, 06:35 AM
DOC DOC is offline
I have used damaged hoods from the wrecking yards to make patch panels, you get them dirt cheap and already have a factory rust preventor alreay sprayed on.
Old 10-19-2004, 08:06 AM
md1twal3 md1twal3 is offline
FYI...I spoke with a metal man and a body man yesterday. 20 gauge is recommended for body and 18 fir structural. I used 20 in the fender patches I made and it was just right for welding and bending.
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 10-19-2004, 11:17 AM
PetesPonies PetesPonies is offline
yes use 20 ga, plus any big city will have a metal supply. They will have 4 x 8 sheets of different gauge steel. My last sheet was $20 for 20 ga.
Pete's Ponies
Mustang RUSToration & Performance
Old 10-20-2004, 10:25 AM
78 GHOST 78 GHOST is offline
I purchase my steel at a local steel supply house which also houses a recycling area. I seem to always find the required metal in the recycling area. I bought 2 sheets of 18 guage a while ago for under $10.
____________________________________
"I work in high speed aluminum tubing."
Old 10-21-2004, 08:17 PM
Ok great advice, I will pick up some 20 gauge.
Thanks for all of the input!
previously owned
78 Firebird
67 Nova
64 Nova
