Old 10-09-2004, 05:47 PM
Torment's Avatar
Torment Torment is offline
More results to share with the durability of the Cometic gaskets. A couple months back I lost a piston (right before Norwalk) due to bad fuel. With the motor obviously running poorly I noticed no indications that I'd hurt the Cometic gaskets. With that in mind I cleaned off the specs of molten aluminum on the one gasket - actually put them in my tub in some lukewarm soapy water, gotta hide that stuff from the wife - and reused them when I put it back together. This past weekend I made 8 passes recording a best pass of 148mph at 3750lbs and had no issues with the gaskets sealing both compression and water. This is with a factory block and ARP head studs. I'm definitely impressed with the durability of these gaskets and thought I'd pass this on to those considering different options to better seal their cylinder pressures.
The secret to happiness is not getting what you want but rather, wanting what you have.
Torment's Avatar
Old 10-09-2004, 05:54 PM
Paul Spotts's Avatar
Paul Spotts Paul Spotts is offline
Great! - I love them here - I'd use them on my dragster if both my heads and block were not already o-ringed. We sell a bunch of them. Great product
www.spottsperformance.com
East Coast Pontiac engine builder - still going strong
4 month waiting list
email [email protected]
1981 Trans Am 455 w/6X heads 4 speed 4 wheel disc (for sale)
1969 Trans Am clone 9.79 at 139 so far
1964 Banshee clone project - Opel GT platform
Old 10-09-2004, 06:59 PM
SupergasDil's Avatar
So are you guys using these gaskets in high compression applications?
I will be tearing my engine down in about a month just to go through it. I am using 6H D's Which is better, O Ring or Cometic?
I'm mainly running on the street but when I go to the track I want to pump up the boost. I've had great luck with my Felpro 1016's up to about 12.25 to 1 but want to be safe. How much compression will the cometics safely handle?
Old 10-09-2004, 07:55 PM
"Mike Kasparian
Send a message via MSN to
I switched this year from copper gaskets and o-ring to cometics and no leaks at all.Motor is
15:1 compression,9.90 3600lb car,50 plus runs.I
had cylinder pressure leakage before with copper.I just put in copper o-ring wire and filed flat and smoothed finish,works great!
Cometic headgaskets are a great product. MK SR.
Old 10-10-2004, 12:33 AM
Torment's Avatar
Dil, I'm at 8.5:1 static with 12-13lbs of boost. I was having difficutly with the FelPro's prompting the switch. If these hadn't worked I'd be o-ringing. If you'd want my opinion, I'd highly recommend them.
Old 10-10-2004, 12:34 AM
Maximum Race Engines Maximum Race Engines is offline
Supergasdil-
Don't waste your time or money on o-rings and copper. Go with Cometic. I have been using them for years on all my customer's engines and my own with zero problems and they are alot less money. They are also reusable.
Joe Pontiac
www.maximumraceengines.com
[email protected]
Old 10-10-2004, 05:51 AM
dutch injun's Avatar
dutch injun dutch injun is offline
That is very encouraging! Can't wait for mine to arrive. Paul, any news on shipping? Mark.
Old 10-10-2004, 10:40 AM
I'm glad to hear about the great results with cometics. Looks like all I need to do is get the new finish on the deck and heads and I'll be set.
Old 10-10-2004, 11:11 AM
dammen8's Avatar
dammen8 dammen8 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by SupergasDil:
I'm glad to hear about the great results with cometics. Looks like all I need to do is get the new finish on the deck and heads and I'll be set. <HR></BLOCKQUOTE>
speaking about the finish for the block and deck...what kind of a finish does the cometics like?
Chad
3500lb 10.5" tire. [email protected] with a poor 60'
Old 10-10-2004, 02:58 PM
Dammen8,
I'm not sure what the finish is called. Ray at Dougans showed me his new machine and it provides an ultra smooth finish. About like a vega finish in a cylinder. The finish I have now is good, but you can see the machine lines. You can also feel them.
Are any of you guys running the cometic gaskets without the mirror like finish on your surfaces?
Old 10-10-2004, 07:22 PM
J.C.you's Avatar
J.C.you J.C.you is offline
has anyone tried running cometics with the orings still installed?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 10-10-2004, 07:52 PM
Mark - yours went out on Friday
JC - you do not want to use them with o-rings - the gaskets are embossed. You'll need to have them filed flat. The viton coating seems to be friendly to all machined surfaces - but a bad decking is just an invite for trouble on any gasket
Old 10-10-2004, 09:19 PM
BVR421's Avatar
BVR421 BVR421 is offline
whats the trick for reusing gaskets? any gaskets?
Im talking about preventing peeling when removing.
Ive tried a thin film of grease and that seems to make a varnish that lets them lift off cleanly with little damage. Havent tried that on head gaskets only intakes.
Im guessing the best bet is to install head gaskets clean and dry?
Old 10-12-2004, 07:24 AM
bad69bird's Avatar
bad69bird bad69bird is offline
Paul or Joe,
I looking to run between 18-20#s of boost thru a 9:1 motor. Which set up do you guys think would be best...an o-ring or Cometics??? Thanks.
-Brian
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 10-12-2004, 11:21 PM
J.C.-
As Paul said, you can't run them with o-rings. Sometimes you can mill the block carefully with the o-rings installed, and the ring will act like a filler, and then run the gasket on top. I have run gaskets of any type on the deck AFTER removing the rings, even with the grooves still in them, provided that the fire ring of the gasket surrounding the bore is closer to the bore than the groove. If the fire ring interferes with where the o-ring was, then you will have to fill it. The Cometics seal with raised embossments around the water holes and bore. If any of the embossments interefere with any holes, it will not seal. The standard type gaskets are more forgiving, so always check.
Bad69-
Cometic. You will not need to o-ring the block, run copper gaskets and receiver groove the head. The cometics work the best, and have no problem with them on crazier combinations that you will be running. They are a Multi Layered Steel (MLS) gasket, with the top and bottom coated. They do require a very smooth clean flat surface on both the heads and block to be optimum. And they do not go together with any silicone or copper spray. That actually hurts their ability to seal. Run them right out of the box, and they are reusable.
Joe Pontiac
[email protected]
Old 10-13-2004, 06:05 AM
bad69bird's Avatar
Joe,
Thanks for the input. It is greatly appreciated!!!
Old 10-13-2004, 11:08 AM
This is good info. Thanks Guys.
Hey Bad,
Have you seen any hot girls lately that you were afraid of?
Old 10-14-2004, 05:40 AM
bad69bird's Avatar
Hey Bad,
Have you seen any hot girls lately that you were afraid of? <HR></BLOCKQUOTE>
Super,
I always see hot girls and I'm certainly not afraid of them, but I've been in remission for the past 10 years...I mean married for the past 10 years. LOL
Old 10-14-2004, 05:51 AM
Bandit79403Dave Bandit79403Dave is offline
Use Cometics on my 403 Olds...12:1 and reuse them between inspection tear downs...pushing 700 horse btw...They are a little more now, BUT WELL WORTH IT!!! Cometics are fantastic!
403 afficionado...made it my personal quest to maximize the power potential of the 403.
www.fcrperformance.com
