Old 06-22-2004, 07:39 AM
onebad403 onebad403 is offline
(THIS IS ALSO POSTED ON 77-81 T/A TECH) My 79 T/A was doing just fine electrically when my son started to wiggle a headlight connector to get it to turn on (at the time the inginition was turned on, car not running, headlights and hi-beams on). One of the low beams was not on, so he tried to wiggle that connector. He got it to turn on and then jumped in the car to start the car. The car just went dead (no cranking, no lights, no buzzer, etc). I tried to jump the car, but nothing is coming on. We checked the fuse box, but didn't really find anything. My thoughts after looking at the wiring diagram is a possible bad battery cable or something called "fuseable link"? When I get home today, I will check the battery, to rule that out, but what else could it be? I have never seen a car with absolutely no power, especially with jumper cables connected. Another interesting thing that happened while troublshooting was that after trying to jump start the car, we did notice the dome light come on after we were about to call it a night, so we jumped in and tried to turn the ignition, the car went completely dead again. If it is a fuseable link, where is it located? Could it be a loose wire from the positive terminal to the starter? (I don't believe in things becoming "loose" all of a suddent, so I havent checked it yet). With nothing coming on and the jumper cables connected, it is acting like an open circuit from the power source.
Old 06-22-2004, 07:55 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Sounds like a bad battery cable connection somewhere to me. Make sure the ends are tight on the battery and if you have the bolt on terminal ends they like to come loose from the cable over time and corrode. Check both ends of both battery cables. Watch your lights and wiggle both cables around. I think if it were a fusible link it would not have started working again for a little bit. Another time I had somethng like this happen my main firewall harness bolt was loose(holding underhood wires to fuse box). Tightened it up and was fixed. Good luck finding it, I hope something here helped.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
