| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
I'm new to this "corporate world" and have a couple questions. '89 Firebird Formula with an '88 5.0 (305) engine.
1) Ignition Timing Adjustment: The "VECI" label on the hood and the Clymer manual I have both state disconnect the single wire timing connector. A tan wire that breaks out of the wire harness. The only single wire connector I find is a white wire and it kills the in dash tach. Is this the bypass wire for timing? Right now it does not effect the mark position connected or not. 2) I adjusted the valves according to Clymer. Rotate pushrod between fingers until zero lash then tighten one full turn. Well I ended up with an engine that would not start The procedure was #1 firing position adjust 1, 3, 4, & 8 exhaust. 1, 2, 5, & 7 intake. Rotate 180deg adjust 2, 5, 6, & 7 exhaust. 3, 4, 6, & 8 intake. This is a roller cam I believe as the lifters have two flat sides to prevent rotating. What is the correct proceedure for adjusting the valves? Thank you for any input, DanC ------------------------------ I'd rather be Historically Accurate than Politically Correct ! [This message was edited by DanC on January 26, 2004 at 03:12 AM.]
------------------------------ 1968 Firebird Convertable - my original HS car! 1978 Firebird Esprit "survior" 1930 Ford Model A Coupe .. (original) 1994 Buick .."TowMaster" ...woody wagon |
