Old 06-26-2004, 02:32 PM
Peje Peje is offline
Hi again! Is it any visible diff between a aircleaner from 1969 and 1970?(the dual snorkel type) Best Regards Peje
Old 06-27-2004, 08:47 AM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
No they are the the same.
I always liked the HO open Air Cleaner...
More air Cooler Looking
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 06-27-2004, 06:35 PM
David Jones's Avatar
I kinda go for the dual snorkle. Good luck finding a good one.
Old 06-27-2004, 08:29 PM
JEFF KING's Avatar
<span class="ev_code_GREEN">Got to admit that looks Sweet!</span>
Old 06-28-2004, 06:35 AM
Blue'69's Avatar
Blue'69 Blue'69 is offline
I agree, Dual Snorkel is the best!!
'69 GTO Convertible-Liberty Blue/Parchment
'71 Grand Prix SJ 455-Triple Black-Sold
'84 Corvette-Bronze/Bronze
Old 06-28-2004, 08:45 AM
Sport71's Avatar
Sport71 Sport71 is offline
I think the '69 and '70 are slightly different. One of them has a larger angle between the snorkles to accomodate the cruise control unit. Maybe OPH or someone can chime in ...
1971 GTO 455 H.O. Ram Air
Nordic Silver - Black
Old 10-25-2004, 09:57 AM
Mook Mook is offline
Hey guys where does the two vacuum lines go from the top of the air cleaner?
Old 10-25-2004, 12:36 PM
air inlet thermal vacuum sensor
Old 10-26-2004, 10:26 AM
The inlet is located under the air pan? Where can I get an inlet? Mine has melted. Does enough vacuum accumulate in there to open and close the flaps on the snorkels? Does anyone know how long the hoses should be? thanx
Old 10-26-2004, 10:42 AM
The switch is in the bottom of the air cleaner pan. Perf Years sells them and I'll bet they are available at a parts store near you. Do they work? I don't know if mine do or not and really don't care too much. My car always starts and runs smoothly when cold as it is, so I'm not one to mess with a good thing The hoses couldn't be over a foot long each.
Old 05-22-2005, 05:16 PM
blownb310 blownb310 is offline
I am restoring one for my '69 Custom S right now. It's not original to the car and it has this part number on the "Keep your car all GM" sticker on the side" RA 6486135. Can anyone steer me to an air cleaner part number reference list? I'm curious as to what model car this air cleaner came off of. It has a production date of 8/15/69.
Thanks,
Mike
Old 05-22-2005, 07:09 PM
The GTO Restoration guide lists the part #'s for GTO air cleaners. I can't tell you if those #'s match the Custom S #'s or not. If the number you list is actually on the "Keep Your Car All GM" sticker, I'd bet is the stickers parts #. I think the air cleaners # is on the bottom of the air cleaner assembly. The production date says it was for a 70 model.
Old 05-22-2005, 07:29 PM
Thank you David.
As is so common, the snorkels on my air cleaner have numerous small dents in them. I noticed that the single snorkel air cleaner on a '72 Lemans [on ebay] pictured here:
looks to use the identicle snorkel as used on my dual snorkel unit. They maybe a good source for "donor" snorkels.
Old 05-23-2005, 04:24 AM
Where are the dents? Mine also had some dents in them and I was able to push all but one out using long Phillips screwdrivers. Similar to the way these dent removal guys do it to a car. The ends of my snorkles were fairly ratty also and I restored them by rounding them out again using the radius of my trusty Phillips screwdriver, a small hammer and a pair of smooth jawed pliers.
Old 05-23-2005, 05:31 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by David Jones:
Where are the dents? Mine also had some dents in them and I was able to push all but one out using long Phillips screwdrivers. Similar to the way these dent removal guys do it to a car. The ends of my snorkles were fairly ratty also and I restored them by rounding them out again using the radius of my trusty Phillips screwdriver, a small hammer and a pair of smooth jawed pliers. </div></BLOCKQUOTE> Thanks for the tips. One snorkel has numerous creases in it. I got most of them out with a small hammer and dolly. Maybe I'll try a thin coat of plastic filler and careful sanding to get it perfect. I too straightened out the radius of the ends of the snorkels.
Have you ever noticed that when you see an air cleaner like this on ebay, the seller almost never takes a close up picture of the snorkels? If I had a perfect one, I'd really show how nice it is with good close pictures.
Old 05-23-2005, 06:12 AM
I've looked at many. Never a good shot of them. Good point. The ends of these things are incredibly delicate. I spent some considerable time straightening mine and then promptly dropped it accidently and got to start over again.
Old 05-24-2005, 06:39 PM
Ive got another qustion please. I want to connect the heat riser tube to my dual snorkel air cleaner. I'm looking for a heat riser tin sheild that goes over the left exhaust manifold to connect the heat riser tube to. In the catalogs I see that they only list one for the Ram Air III and all round port head exhaust manifolds. Does anyone make a reproduction heat riser sheild for standard exhaust manifolds?
Any idea why these stamped sheilds are close to $100?
Old 05-24-2005, 07:35 PM
Percy's Pontiac usually has standard shrouds. There is one on Ebay right now that goes off in 21 hours.
Old 05-25-2005, 05:48 AM
Michael, check your email.......
