Old 08-05-2003, 09:00 AM
Donovan Donovan is offline
I've modified a pair of 97 TA LT1 electric fans to fit my aluminum radiator. The darn thing stays at 190 and won't move any higher. I'm also using a thermal switch and relay setup made by hayden. If you look at the pics you can see the brackets and sensor fitting I had to weld in to accomodate the fans. I've posted some pics of the install here.
http://community.webshots.com/user/kickinchicken
______________________________
1968 Firebird Coupe - 3665 lbs.
350 HO
Long Branch Manifolds
TH350
3.23 open BP axle
PS, PDB and Deluxe interior
GPE Starter ... Small body HEI ... 2.5" Pypes w/X-pipe ... Ruggles Qjet
14.1 @ 99.1
