Old 11-16-2004, 04:00 AM
Formula8's Avatar
Formula8 Formula8 is offline
Change the manifold to a Performer when you add a Crower 60919 cam with Rhoads lifters. Tunnel Port has Tri-Y headers available for the D Port/auto configuration right now. Pypes 2.5 X-pipe or X-change system with Dynomax ultra-flows. This cam is a little much for your stall/gear combo but should work fine with your future head swap assuming you are looking at KRE's heads.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
