Old 06-19-2003, 05:15 PM
80TA 80TA is offline
I am torn between small and big block for my car.I was told that the big block will require removal of my airconditioning hump or whatever you call it on the firewall the thing with the relay on it and some wiring.I have already taken off my air compressor and condenser and stuff.So do I have to take this out to get the big block to fit or to be able to change plugs etc.And can I put on the hump heater cover thing from non air car and will it be possible to rewire things so I can still have heat and defrost .My car is street driven in fall and spring and it can still get pretty cold around here .nice to still have heat and defrost.
80TA,pontiac 400,edelbrock carb,accel wires,dual exhaust,dynomax mufflers,no cats,3.42 gears.CE subframe connectors to be installed.On order B&M quicksilver.
15.1 at 96mph 2.47 60ft uncorrected tazzo vpc.
99TAWS6 ..lots of mods.13.35 at
109 2.27 60ft uncorrected tazzo vpc.
1900 ft altitude.
80TAWS6,400,edelbrock 750 carb/performer rpm intake/crane cam and lifters,/magnum 1.52 rocker arms/comp pushrods/arp rocker studs,cloyes double roller,crower valve springs,ias shocks,msdl wires,dual exhaust,flo pro mufflers mufflers,turbo 400, 2400 nitrous holeshot,3.42 strange gears.
