| The Body Shop TECH General questions that don't fit in any other forum |
Where can I get 18 gauge steel. I have looked in welding shops, Home Depot, Lowes. All I can find is 16/14/20/22 etc....
That is the correct thickness for auto body panels.......isn't it?
Bring back my 67 GTO: Shes ALIVE as of 2-19-13 previously owned 78 Firebird 67 Nova 64 Nova |
I would prowl around the weld shops more or maybe try some machine shops. If they do not have any scrap, they should at least be able to order you some or point you in the right direction. 18 ga. should not be that hard to find, we use a ton of it in our shop (we're a medium sized machine shop).
The joker in the deck keeps sending me his card. Smiling friendly, he takes me in. Then breaks my back in a game I can't win. |
Also check ventilation and siding companies. I got mine from York Corrugating, who mostly supply ventilation contractors. They wanted to give me galvanized, but I asked for cold-rolled as I was going to have to weld it.
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward." |
Almost forgot, the corrugating Co. was 1/4 the price of a steel supply shop. Go figure...
Thanks I will go look at these sources
Troy
Troy,
18g is a little thick for general body work isn't it? It is pretty thick for trying to bend around different curves and contours. I prefer 20g for body and 18 for more structural body fabs such as trunk supports and body bracing. |
Mr. Bruce has a point. I bought a sheet of 20 gauge myself.
I have used damaged hoods from the wrecking yards to make patch panels, you get them dirt cheap and already have a factory rust preventor alreay sprayed on.
FYI...I spoke with a metal man and a body man yesterday. 20 gauge is recommended for body and 18 fir structural. I used 20 in the fender patches I made and it was just right for welding and bending.
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi |
yes use 20 ga, plus any big city will have a metal supply. They will have 4 x 8 sheets of different gauge steel. My last sheet was $20 for 20 ga.
Pete's Ponies Mustang RUSToration & Performance |
I purchase my steel at a local steel supply house which also houses a recycling area. I seem to always find the required metal in the recycling area. I bought 2 sheets of 18 guage a while ago for under $10.
____________________________________ "I work in high speed aluminum tubing." |
Ok great advice, I will pick up some 20 gauge.
Thanks for all of the input!
