Old 04-21-2004, 07:36 PM
issach428's Avatar
issach428 issach428 is offline
I am changing my multi leaf springs to the caltracs split monos. What have you guys that run the split monos use to make up the difference in the fewer springs??i dont want to switch to the ford 9 inch pads. Should i use the rubber pads that sandwich the springs??
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
issach428's Avatar
Old 04-21-2004, 08:26 PM
Brian Baker's Avatar
The axle sits on top of the spring, so why are you concerned about having to "make up" for fewer leaves? If the mono's have the correct rating, ride height will not be effected. Hot Rod would be the one to ask about perch width, however.
Old 04-21-2004, 09:53 PM
72firechicken 72firechicken is offline
Calvert recommends eliminating the rubber that sits in between the perch and the spring, I am not sure about the one that goes below the spring. What I did was get a one inch lowering block at my local parts store an custom ground them down and set my pinion angle at the same time by grinding the front thinner, by the time I was done the blocks were pretty thin but still strong and I reused the rubber bottom portion until I get some new ones that are urethane from summit.
Old 04-22-2004, 05:42 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Measure the differance and make a steel plate to compensate for it.
Old 04-22-2004, 07:04 AM
Ron's Avatar
Ron Ron is offline
I removed the GM perch and installed Ford 9 inch spring perchs. This is what John Calvert recommended to me.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 04-24-2004, 04:52 PM
issach428's Avatar
i ended up using a realy thick steel plate on bottom of the leaf spring and a 2 degree shim on top.
