Old 05-25-2001, 01:12 PM
LarryF's Avatar
LarryF LarryF is offline
Mike, try Jon Hardgrove at the Carburetor Shop in Missouri. 573-392-7378. He also has a website at www.thecarburetorshop.com. Ames Performance also sells his rebuild kits, which include most of the screws if you get a level 2 kit (I don't recall if the throttle plate screws are included). I can't give you an answer on the jetting, but Jon can probably get you close. Bear in mind that he will probably tell you that using a carb from a different engine will require all kinds of internal recalibration (bleed sizes, etc.), but I think you can get close enough with jet and metering rod changes. Jon occasionally posts on this board as "Carbking."
Larry
'63 421SD LeMans...
in pieces in my garage
and basement
Larry
'63 421SD LeMans...
and basement
