Old 01-20-2003, 07:37 PM
cuz68's Avatar
cuz68 cuz68 is offline
A friend of mine has a 84-TA, he has bleed all the brakes, it has 4 wheel disk. What could be wrong? He can't get the brakes to work.
Cuz68
cuz68's Avatar
Cuz68
Old 01-20-2003, 08:16 PM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
the way the rear disc are made it could be anything are they not geting any pedel at all? on my 85 with disc the rear caliper exploded are alot of times the rear stick, if you turn the pistion the wrong way they explode, if the pistions went back ez then i doubt thats the problem. did he do a swap? or is it a factory disc break car? if he swaped the perpostioning valve is diffrent. i really need to know whats happening or not happening to give you a better idea what to look in to.
http://home.earthlink.net/~saawatson/ my 1983 trans am. PONTIAC POWERED
Old 01-20-2003, 09:06 PM
cuz68's Avatar
the pedle has no breaks the pads have never been changed,did not know the pistions could be turend,it is a factory disc car ,it has been sitting about 12 years,that is why he quit driving it.
Cuz68
Old 01-20-2003, 09:59 PM
yes the pistons turn to go back, instead of just pushing back like front disc. sounds like the master cly has the rod stuck wide open, does the bleeders have any pressure when bleading them or is it more like a drip? or just a little squirt? i woukld remove the master cly and replace it. and make sure you bleed the new master cly before the install
Old 01-20-2003, 10:23 PM
cuz68's Avatar
thanks thirdgen/455 will look at that tomorrow, again thanks a lot.
Cuz68
Old 01-20-2003, 10:25 PM
cuz68's Avatar
thanks thirdgen/455 will look at that tomorrow, again thanks a lot. will let you know what goes on.
Cuz68
Old 01-20-2003, 11:06 PM
no problem i hope thats all it is.
