Old 03-03-2003, 01:47 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
Where can I buy a replacement clock movement for my 1968 GTO Rally Clock?
The electro magnet that winds my clock is burned out.
The hands, face and lens are in great shape.
I have it apart and it looks like a replacement should drop right in.
Will a later model clock movement work?
Thanks,
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Hi,
Thanks,
Mike
Old 03-03-2003, 01:57 PM
EnergyFX EnergyFX is offline
I rewound the coil on my clock about a year ago and it is still working fine.
Go to Radio Shack and buy a pack of their varnished coil/electromagnet wire and have fun. I think I did like 250 wraps but I don't remember for certain.
__________________________________________________ ___
I don't see it as just a job, I see it as one third of my life.
Ja Whitfield
Old 03-03-2003, 02:46 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
Instrument Services Inc. out of Roscoe Illinois carries the original clock movements or the newer quartz movement up-grades.
Toll Free 1-(800)559-2674
Illinois (815)623-2993
Fax (815)623-9180
They also repair your old in-dash clock here through Performance Years.
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
[This message was edited by 1-GTO on March 03, 2003 at 06:00 PM.]
Old 03-03-2003, 06:49 PM
Hi,
The plastic around the coil is melted, so I'm not sure I will be able to rewind the coil.
Sure wish it would be that easy.
I might also have to clean the gears and timing wheel because they don't turn real well.
I'll check the sources provided.
Thanks,
Mike
Old 03-03-2003, 07:37 PM
Should just be a steel core in the middle, get down to that and you are good to go on rewinding it yourself.
Ja Whitfield
Old 03-03-2003, 08:23 PM
PonchoV8 PonchoV8 is offline
Might try to find a quartz movement if your car sits for long periods. I have 2 or 3 clocks that work for my cars. I just had to spray the works with some lubricant to get them to operate as they are supposed to. If you find a spare cheap enough, just swap them out too. I know of about 20 clocks in a junkyard for my spares. They just suck to remove.
Doug
"...then grease me up woman." Groundskeeper Willie
www.geocities.com/yqtnxnb
Old 03-04-2003, 11:56 AM
natep natep is offline
I have a quartz replacement kit on the way from OPG right now to fix my 68 rallye clock. I'll let you know how it turns out - it was about $70 w/ shipping.
Old 03-04-2003, 08:54 PM
vidguy's Avatar
vidguy vidguy is offline
about 6 years ago, I bought a cheap movement from a clock store, and just made the hands fit on. It wasnt too hard. And the movement cost me $10.00 It runs on 1 AA battery. I ran the wires out the little hole and double taped the battery to the back of the clock..I dont use the clock anymore but it ran for a couple of years that way. I might still have it somwhere. I'll look.,.,
James Fasso
[email protected]
'67 GTO Conv
"220, 221, whatever it takes."
Micheal Keaton as "Mr. Mom"
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 03-06-2003, 11:44 AM
APAK APAK is offline
I took mine apart and cleaned it up nice but now it runs fast. Every couple hours I have to reset the time. Anyone come across this?
"I've got the fastest looking car standing!"
Old 03-06-2003, 08:47 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
I purchased the quartz replacement kit from instrument services mentioned earlier. Installation was easy and your purchase includes a "how to" video. The quartz clock will be much more accurate than the original movement.
Regards,
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
Larry Metzger
Columbus, NJ
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
