WHAT'S THE BEST INTAKE FOR A 455 EHEAD (87cc), 292 COMPCAM ( 244DUR.@ .050 )ENGINE. THE CAR IS A 79 TA THAT WEIGHTS 3200 W/O DRIVER, 400 TRANS, TIGHT 3000 STALL, AND A 3.42 REAR END.
I like the Torker 2.
With the "shaker" you'll need to use the Torker II.
Dave "Big Injun" Anderson www.pontiacdragdays.com www.geetotiger.com
Dave "Big Injun" Anderson [email protected] www.4mypontiac.com For GTO Celebration items click the tile coaster.
RPM is just as good, but it,s too tall for your ta,s shaker set up
--------------------------------------------------------- "GTO? Good Times Only!!!" "Get Tools Out!!!" ---------------------------------------------------------
--------------------------------------------------------- "And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor?? --------------------------------------------------------- |
I like my 455 / torker II. People say, "oh, but the rpm has .x % more low end torque", but with a 455, you already have more torque than the best steet traction can handle. I think the good fit under the hood is a big factor. Mine makes a definite "waaaaahhh" sound at about 4K rpm that I really like too- bonus+.
-Mike I'm right at home in a filthy garage
I'm right at home in a filthy garage |
I too like the T2. Used it on my 400, now my 428.
Shaker can be discreatly altered to use most carb/intake combos, including the RPM. SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY. I Misus Rash'!
![]() SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY! |
Last summer I dyno tested both on a 455 with unported E heads, Crower 60919 cam, and HS 1.65 rockers. The T-II made the highest peak numbers, both torque and hp. Nearly as I can remember the highest peak hp was 505 for the T-II and 494 for the RPM.....Cliff
What carb are you using?
67 GTO, 428, Q-Jet, TH400, 3.42, 12.50/107.5, whisper quiet 67 GTO, 400, Q-Jet, M20, 3.23, 14.02/98.7, loud & obnoxious |
But, if you want to run the RPM, you can always use the Blocker High Velocity Induction System to make it fit.
http://www.blockersperformance.com
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
