Old 08-07-2001, 08:31 AM
66Bronz 66Bronz is offline
Hi everybody, will the stock timing cover of a 389 suffice as a battery ground??? I think its cast iron (?) Why am I asking this question? well I bought new steel braided battery cables, & the ground won't fit the new head bolts- too small. So, I was wondering about the timing cover, on the "foot" in the lower corner... thanks for other suggestions too!!
Old 08-07-2001, 08:38 AM
Goatman Goatman is offline
On Vacation
I would try grounding it to the front of the head, where the accessory bolt holes are.
Old 08-07-2001, 02:01 PM
Old Man Taylor's Avatar
You could also use a header bolt. I would not ground it to the front cover.
Old 08-07-2001, 03:57 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
My wiring Guru recommends connecting the ground cable directly to one of the starter mounting bolts.
Old 08-07-2001, 05:31 PM
Play400 - If he already has a braided wire made up it will be too short.
66Bronze - Are you trying to attach it to a head bolt with a stud on it? If so, and if it won't fit there, then the suggestions made above also will not work. You will have to open up the hole in the terminal, or get the wire re-terminated.
Old 08-07-2001, 07:48 PM
Isn't the front cover aluminum?
If so, do not ground there as it will produce / accelerate electrolisis between the differing base metals.
As mentioned above ground to the heads or block.
Old 08-08-2001, 08:43 PM
OMT- Thanks, I'll put it on the header bolt. I shyed away from that because I thought the heat there would compromise a good ground, but I always look for your posts & if you say it'll work, that's good enough for me. Yea, the cable is way too short to reach the starter. Enlarging the terminal-end is not an option, because there's not enough material. The original ground was on a stud, but replaced all round with bolts- the car won't be seriously raced & the heads won't be coming off often (I hope!) Thanks again guys
