Old 05-03-2003, 09:11 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
This is for the 455 in my 85 Cutlass, wrong forum I know but just pretend I said 85 grand prix . I have a 70 olds 455 with the C casting heads and I have to pull this engine to swap it into a solid body. While its out im going to regasket it and am thinking of dropping a different cam in as well as this engine has never really had any pop for some reason. I think i had a factory cam put in by the place that built it the first time. I would just like to know whats a good cam choice for a strong street motor? On 442.com faq section they suggest a mondello JM20-22 i think it was. I am also running a holley 900cfm pro jection on this motor. It is way to slow for a fuel injected 455. Any help from anybody knowledgeable in olds engines would be appreciated.
Thanks again!
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
