Old 02-02-2003, 05:47 PM
KVman389 KVman389 is offline
Have a 66 gto, pretty much stock with HEI ignition. Recently, whenever I turn on my turn signals, the headlights, dash lights blink in unison with them. When the brakes are applied, everything dims. Voltmeter fluctuates in unison with the flashers, and drops 1.5-2 volts, also drops when brakes are applied, but recovers almost instantly. Have checked all grounds, (I think). Battery, alt., starter, and regulator check out ok. All visible wiring appears good. Please help,only option I can think of is a full trace of the charging system. Thanks.
Bert
i
When I turn it on, wind it up, blow it out GTO
Bert
i
Old 02-12-2003, 02:26 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Geez.... This is gonna be a long one to find.
Does it happen only with the engine running? If so, it's something in the charging system.
Otherwise, disconnect stuff (or pull all the fuses) until you find the culprit.
I had a tach that did this to my wife's car. It had a bad internal ground.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 02-12-2003, 08:07 PM
george kujanski's Avatar
Sounds like either you have a poor regulator case ground or your alternator can't supply the necessary current under these loads, meaning your belt may be loose, or you are not getting enough output from the alternator. Possibly an open diode in the alt? Check to make sure you have battery voltage on regulator terminal 3 (battery sense).
Regards, George
Old 02-16-2003, 02:13 PM
PITTSBURGH 64 PITTSBURGH 64 is offline
I would disconnect all the dual filiment bulbs on the car sounds like the break-turn signal circuit is backfeeding to the lighting circuit. Does it do it when the head lights are on, do the break lights come on with the headlights?
Old 02-16-2003, 03:39 PM
sleepy's Avatar
sleepy sleepy is offline
Sounds like a bag ground. Check the ground on the tail lights. I'll bet you find a bad connection or wire.
Why is he not suspended?
Old 02-16-2003, 03:42 PM
sleepy's Avatar
Also look fot power wires rubbed through and grounding to the body.
Old 02-17-2003, 06:40 AM
well let's see, yes, it only happens when the engine is running; no the brake lights don't come on when lights are turned on. New alt. belt, torqued to 75lbs. Will check the tail circuit next, then check signal and brake switches. Yes it also happens with headlights on. Thanks for all the new ideas, will make for a full day. will let you know if I find the specific problem. Again, thank you.
Bert
Old 02-17-2003, 08:25 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
I would check the turn signal wiring going into the steering column. It sounds like a wire is grounding out. I would loosen the bracket holding the bottom of your column and jiggle the wire harness by the metal cover and see if is the problem. If your dimming problem happen's only when the turn signals are "on" this harness is what I would check first.
Good luck, wiring is a pain.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph
Old 02-20-2003, 03:23 PM
nickg nickg is offline
try pulling the instrument panel fuse first to try to isolate circuit sounds like a bad ground or bad turn signal sockets are notorius for that also if you recently to the instrument panel apart you may have check to make sure all the screws are in & the circuit bord isn't folded over or otherwise damaged.
Old 04-04-2003, 07:55 PM
thanks for all the great info. Took a while to get to everything. Finally got down to the starter and solenoid, found a bare section on the ground, and the field strap was missing the screw.Replaced ground, secured the field strap, Problem stopped, and has not reappeared. This might help someone else who runs across this problem. Again, I thank all of you for your information and advice, I did find a couple of potential future problems while going through all of the checks. Bert
