Old 02-01-2005, 05:32 PM
jamaca85 jamaca85 is offline
has anyone experienced a ticking noise coming from the motor on the 5.7l ls1 motors in the trans ams?? i have a 2002 ta, and noticed this noise, took it down to the dealership, they said that it was coming from the#1 piston. they said it was comon among these type of motors, due to the design. the noise is there at an idle, then at slow acceleration, goes away at about 2000rpm, also goes away once it is warmed up. .has anyone experienced this with this type of motor?
1970 firebird, 468, e heads,
Old 02-01-2005, 06:20 PM
Larry Navarro's Avatar
I was informed that it has to do with fuel pressure and the ticking noise is associated with a system shuttle valve on cold start-up.
I experience the same thing on my '96 vortec v-8 with 170K miles...which runs perfect.
Suposedly nothing to worry about.
Old 02-01-2005, 07:45 PM
Young One79TA Young One79TA is offline
Same thing happens on my brothers '98 T/A and it's running fine. So I guess it's nothing to worry about.
Old 02-01-2005, 08:30 PM
Hawk397 Hawk397 is offline
Send a message via AIM to Hawk397
Don't let it worry you. Aluminum block and a aluminum short skirt piston make for some piston slap. (worse when cold) My '99 sounded that way since day one and still runs 1O's on the stock bottom end!
71 Firebird Custom - Fuel Injected & Over-drived!
Old 02-01-2005, 09:22 PM
455firebird1969's Avatar
My 98 TA has a slight tick, I never gave it much thought until reading this. It is so smooth, yet powerfull, its a great engine...
Old 02-01-2005, 10:01 PM
67vertBird 67vertBird is offline
Most likely a bent pushrod, VERY common with these when revved a little too high, like a missed shift. Not a big deal to change them out. Don't bother getting stronger ones, it is cheap insurance to let them bend first. Gee, makes me miss my 99 SS.
67 Firebird 400 Convertible (sold)
Old 02-02-2005, 04:17 AM
i just found that odd that gm would design such a great motor, with this one flaw. i heard the vettes have the same problem too. thanks. the guy at the dealership told me the same thing. 8 of 10 of these have the ticking. kind of worried me especially only after 24k miles thanks
Old 02-02-2005, 05:44 AM
C'mon....
GM design and "flaw" go hand in hand.
Old 02-02-2005, 07:44 AM
satman's Avatar
satman satman is offline
I saw an episode of Horsepower TV recently, they had one in a Camaro, they showed us taking it apart, piece by piece, don't think they ever came up with an exact conclusion.
see link
http://www.horsepowertv.com/show_details.aspx?iid=4140
Old 02-02-2005, 11:35 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
If it goes away when warm and you are not using oil, then I wouldn't worry about it too much.
If the car is using a lot of oil then I would be concerned.
If it is a BAD ticking, it could be bent pushrods.
Old 02-02-2005, 11:42 AM
critter's Avatar
critter critter is offline
It could also be piston slap due to carbon build up which is a common item on these cars.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 02-02-2005, 11:52 AM
R/ABANDIT R/ABANDIT is offline
That's what it is Piston slap. But it's because of the short skirts on the Piston they put in the motors now. My northstar dose the same thing in my STS.
1977 Trans Am 400CI R/A IV.
**Looks can be deceiving**
Old 02-02-2005, 05:39 PM
68GTOConv's Avatar
68GTOConv 68GTOConv is offline
It's normal, and will not keep you from embarrassing all the Mustang GT drivers out there. Some have argued with dealerships to get work done which at best will minimize the noise. My '01 never did it, so I guess I was the lucky one. Or maybe the sound of the supercharger just covered the piston slap :-)
Mike M
Old 02-02-2005, 05:54 PM
al al is offline
My 99 has piston slap until it warms up. Very common problem for the ls-1
Old 02-03-2005, 10:07 AM
form406's Avatar
form406 form406 is offline
my buddies anniversary ss camaro does the same thing...he switched to better quality oil and that helped but apparantely its a common thing with those motors...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
Old 02-03-2005, 10:13 AM
Tripower455's Avatar
My '01 Formula and '04 GTO both did/do it if I get on it before reaching operating temp.
Short skirt pistons in an aluminum block = a bit more clearance when cold.
Nothing to worry about!
If it were a pushrod, it wouldn't go away when it warms up.
You really ought to take the Chevy out of there and put a RA IV in it!
Old 02-03-2005, 02:35 PM
gtoformula's Avatar
gtoformula gtoformula is offline
I work for GM. The noise is more than likely piston slap and it is a common characteristic of the LS1. All the posts that said this is not a durability issue are entirely correct. These engines have extremely tight piston/wall clearance, but due to the short piston skirt length the noise develops. The same noise exists with the V8's used in pickups and SUV's (the 4.8, 5.3 and 6.0 engines). I have never seen an engine failure due to the this condition and the noise typically doesn't continue to get louder. If you are not running synthetic oil then try switching ... it frequently reduces or eliminates the noise. If I remember correctly, GM was putting synthetic in all LS1's just before the "F" bodies went away (sniff, I'll miss 'em).
Old 02-03-2005, 05:39 PM
Ryche400's Avatar
Ryche400 Ryche400 is offline
Ditto....Mine does the same thing. Especially now, thats its colder..
