Old 04-15-2002, 07:13 PM
74redgto 74redgto is offline
Ok, I am now looking at only these two cams, or tweaking numbers around them in a custom grind.
If you have one of these cams in a 400, 9:1, or 10:1 Compression, e-heads, I would like to hear your experience. 276 is stronger on bottom, 288 get advantage after 3500rpm. If I stroke my 400 out make it a big boy, then now question..288
If you have the 276, do you wish you had more?
If you have the 288, is it comfortably streetable.
When I win the lottery, I will build around both, but have to choose one for now.
