Old 03-18-2005, 12:55 PM
trumpeter trumpeter is offline
Took the 74 455 TA out since were are finally starting to thaw and noticed a backfiring through the exhaust. Suspecting a valvetrain problem, I pulled the valve covers and found loose rockers on cylinder #6. To make matters worse, there is no pushrod on the exhaust side.
Next week I'll be tearing it down, but until then where in the world could the pushrod go?
I haven't changed the oil since I got the TA home, but I'm scared it was chewed up and now I'm looking at biulding the motor again.
Any thoughts are appreciated...
Trumpeter
Trumpeter
Old 03-18-2005, 01:10 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Prolly in the bottom of the pan.
Old 03-18-2005, 01:14 PM
David Jones's Avatar
Well, I guess the lifter/lobe could have been eaten and the pushrod either laying in the valley or slid down into the crankcase. Hard to imagine this without some serious racket coming from the engine bay.
Old 03-18-2005, 01:35 PM
There wasn't metal to metal noise so maybe I got lucky....
Trumpeter
Old 03-18-2005, 01:46 PM
Between your legs???
Old 03-18-2005, 02:24 PM
You, sir are a sick man.
I was going to type something similar, but had a case of nut shrinkage.......
Old 03-18-2005, 04:34 PM
gjn gjn is offline
"68 Firebird 461
Send a message via MSN to gjn
I had this happen on my 400 right after my rebuild 6 years ago. Had a piece of rust stick a needle open and hydralic the motor, bend a push rod and chewed it up. I fished 4 of the 5 pieces out of the oil pan with a magnetic telescope. Found the 5th when I rebuilt the motor last year.
GJN
1968 Firebird 400
461
3,580 LBs
3.2k Stall
3.25
1.657 - 60'
11.637 @ 115.45
http://www.youtube.com/watch?v=dEqzw...e=user&search=
Old 03-18-2005, 05:12 PM
Stuart's Avatar
Stuart Stuart is offline
It could be laying in the valley under the valley pan. If you have one of those magnet-on-a-stick things, you could put it down through the pushrod hole in the head and fish around a little.
Old 03-18-2005, 06:58 PM
Maybe all is not lost. I'll get the intake and valley pan off and update everyone.
Trumpeter
Old 03-18-2005, 07:44 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
Maybe the case of nut shrinkage is what caused the push rod to fall off????
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 03-19-2005, 06:31 PM
form406's Avatar
form406 form406 is offline
i toasted a 462 on a freeway on ramp and went back to the scene after gettig the car towed and found one of my pushrods on the street a long with pieces of my mini starter...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
