Old 02-15-2005, 06:50 PM
merlin merlin is offline
I have a 64 Lemans with a 400. I want to block off the ports on the heads that feed the heat riser { both heads }. Any ideas? Merlin
Old 02-16-2005, 11:01 AM
Mr. P-Body Mr. P-Body is offline
Felpro 1233 intake set has optional block-offs. The best way is to fill the passages with aluminum.
Old 02-16-2005, 07:17 PM
Mr. P-Body, Should I use the aluminum with the gasket or by it's self? Merlin
Old 02-17-2005, 07:03 AM
If you fill the passages, you won't need the block-off that comes with the gaskets. If your ports aren't raised to Ram Air IV height, you could use a standard gasket with the filled heads.
Old 02-17-2005, 08:56 PM
Mr. P-Body, I thought you wanted me to use aluminum sheet stock or the gasket, I was confused. That happens alot at my age. Thanks aloy for your help. Merlin
Old 02-18-2005, 02:17 PM
KEV's Avatar
KEV KEV is offline
Hey Gordo!
The method Mr. P-body is describing involves removing the heads to have them filled with molten aluminum.
Have you purchsed your gaskets yet? Shoot me a mail or give me a call to discuss.
Talk to you soon,
Kev
Kevin Swaney
Tin Indian Performance Rear Engine Dragster 7.66 @ 172 mph 494 with KRE High Port Heads
www.tinindianperformance.com
330-699-1358
Old 02-26-2005, 08:28 AM
Kev, I'll call you at home. Again I want to thank Mr.P-Body for his help. Merlin, over and out
