Old 05-28-2002, 08:14 PM
Pittsbor_Gil Pittsbor_Gil is offline
I've got an electrical short. I took all the fuses out and put them in one by one to check. Found it at the 3rd fuse down marked cigar lighter. I disconnected the lighter, but still have the short. I pulled the main fuse box out and found it is an orange/black wire. My Fishers manual doesn't show the wiring for the main box. Anybody have the main harness code for a 66 LeMans? Help in Indy.........
Old 05-28-2002, 11:49 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
The wire that hooks to the lighter should not be that long that you can't trace it back to the fuse panel. Crawl under there and start tugging wires. My guess is the wire rubbed thru on a sharp edge somewhere.
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 05-29-2002, 12:45 AM
vidguy's Avatar
vidguy vidguy is offline
many moon ago...I had my lighter wire rub thru on my old harness. It rubbed on the Ground bracket If i recall.. Check that..........
Bud THANKS For the lock nuts................US MAIL is very slow these days....
Thanks again! Bud deserves ever bit of his Chief PontiacYacker rank!
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 05-29-2002, 01:17 AM
Bud Lyons's Avatar
Sorry it took so long. I just kept forgetting to mail the damn things.
Old 05-29-2002, 09:25 PM
trshman's Avatar
trshman trshman is offline
<font size="2" face="Verdana, Helvetica, sans-serif">I've got a '66 also but have been using a '67 manual that came with the car when I bought it. It has block diagrams for every section of the electrical system and that's what I've been using and haven't had any problems up to this point. If you want to look at what I've got I'd be happy to email it to you if I can scan it without ripping it out of the manual. Let me know.
Bob G.
Old 05-30-2002, 08:06 AM
Thanks for the offer Bob....but i think i have found the problem. I checked the battery again and it was dry. That lead me to the voltage regulator. The contacts were stuck and it fried the water out of the battery. Also shorted out the plates. I'm headed over to NAPA to get a new one tonight and replace the battery. Thanks guys and keep on crusin!!
Old 05-30-2002, 12:22 PM
trshman's Avatar
<font size="2" face="Verdana, Helvetica, sans-serif">Gil,
Glad you found it. Nice troubleshooting. The block diagrams are a standing offer. If you ever want them let me know.
Have a good one,
Bob
Old 06-02-2002, 06:52 AM
dallas dallas is offline
Just don't get one of those Mexican regulators or you might be back doin' it all again. A real GM reg. would be worth the cost.
A life spent making mistakes is not only more honorable but more useful than a life spent doing nothing (G.B.Shaw). At least that's my excuse.
Old 06-03-2002, 12:16 AM
2FAST4U 2FAST4U is offline
Be careful!!! That very same Lighter wire shorted out and burned up burning the whole dash harness and pretty much everything up to the fuse panel and even past it up to the horn relay/external regulator! That incident was the deciding factor to go ahead with a frame off restoration a couple years early Make sure you fix the problem correctly! -Chris
Dont funk with the 455...
