Old 02-27-2003, 10:15 AM
ascreemer68 ascreemer68 is offline
whats your thoughts on using 2 head gaskets to reduce engine compression?
thanx.
http://www.stefanjames.com/goat.htm
thanx.
Old 02-27-2003, 10:51 AM
DAVE RIBEIRO DAVE RIBEIRO is offline
Why not do it right the first time??? Buy the
thick gasket,I know they cost more but they are available...I won't double anything but a steel-
shim gasket,then only as a last resort?? Dave
Old 02-27-2003, 11:07 AM
like having two cheeks
Old 02-27-2003, 11:09 AM
a real screamer 68
Old 02-27-2003, 03:48 PM
no problem purchasing a thick head gasket. any recomendations. ???
had to change my aol email acount cuz i had too many people thinking it was ass creemer 68. doh!
stefan ( a screemer 68 )
Old 02-27-2003, 07:59 PM
I use to be able to get McCord's(0.052),but
they have disapeard?? fel-pro 0.043,then there's
copper? Someone on this site mentioned that there
was a new gasket coming out from some company????
Can anyone help..........How much deck do you need
in this motor? Maybe one of the engine builders,
can jump in ?? LOL...Dave...1033/stock
Old 02-27-2003, 08:24 PM
Never liked it!
Twice the potential for leaks.
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Old 02-27-2003, 10:13 PM
diddly diddly is offline
I too was looking into 'thick' head gaskets as a way too lower the compression in my 455. Everybody I talked to that I considered knowledgable; in racing circuits, machine shops, etc...all said the same thing: NOT for street use! If you're racing, and you're going to be pulling the engine apart all the time, then copper gaskets are okay. But street use will kill them way too quickly; and I was told, "You'll have water everywhere." (Everywhere you DON'T want it, that is.) I was convinced; so instead of using thick gaskets; I'm using a new block!
Old 02-27-2003, 10:24 PM
Why not dish or chamfer your pistons?
I Misus Rash'!
Old 02-28-2003, 11:12 AM
didnt dish or chamfer pistons because my pontiac engine builder is a freak. assured me ova and ova that engine would be fine, ... but running 94 octane on a 10.75 to 1 compression engine aint good. so i was looking into a temporary solution until i gots the bux for deeper work.
Old 02-28-2003, 11:32 AM
Run the Primaries rich.
Cut the sparkplug ground electrode to half-length and side-gap to .035"
Limit total advance to 34degreees tops at 2800RPM and higher.
HIS
"tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs
11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs
12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
