Old 01-31-2003, 09:27 AM
Dalton 66 GTO Dalton 66 GTO is offline
Maybe I can attack this from a different angle. The picture I have attached has my car(top) and a sweet looking gto I downloaded(bottom). I want my car to ride similar to the car on bottom with maybe just a littlemore height in the rear. Can anybody estimate what I need?
Old 01-31-2003, 06:36 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
How about new springs? Are those original? If so, replace them. If you want the rear higher, you can try springs meant for the same car, but the station wagon body style.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 02-01-2003, 06:59 AM
Trev Trev is offline
You could leave the rear end as it is, and cut half a coil out of the front springs.
Old 02-01-2003, 10:37 PM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
Inch or so you can use rear coil spring spacers or coil over shocks, stay away from wagon springs too high!and air shocks ride too hard!
Nice car! good luck with it!
jeff
"...And on the seventh day God raced his GTO!"
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 02-02-2003, 06:55 AM
chris spires chris spires is offline
You could use air shocks that use the little hoses that connect to an air valve. All you do is pump air in, and the rear comes up. Costs about $60 for both shocks and about an hour to install. The kit comes with all you need. It's also available over the counter. I put some on my Cat, and it got the ride height just right. Also, the ride is quite nice as well.
Don't blame me cause your chevy broke down, you should have bought a PONTIAC!!
Hey are you ready to go, got the top turned down on my GTO. Come on,let's all jump in, gonna take this car for a little spin!!
Old 02-02-2003, 07:48 AM
Brew Brew is offline
Stock replacement springs if you want it to look like that GTO, station wagon springs if you want it to sit too high.
Just curious, why do you want it higher than stock?
67 LeMans vert w/462
68 GTO bone stock
Old 02-02-2003, 12:34 PM
PMDRACER's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Just curious, why do you want it higher than stock? <HR></BLOCKQUOTE>
That's how I read his post. He wants it higher than stock. To each his/her own.
-RONALD REAGAN
Old 02-03-2003, 12:25 PM
I just want it to look like it has a little more balls I guess. Right now it looks like grandma's grocery boat. BUT, I'm still in love with it!
Old 02-03-2003, 02:59 PM
theYman's Avatar
theYman theYman is offline
I just finished up a project.It involved buying a set of the coil over springs and putting them over new shocks.It raised the car about 2 inches but wont be as harsh as air shocks.I havent driven it yet but standing and bouncing the rear there isnt alot of movement.The total cost $10.00 for springs and $24.00 for shocks is something to think about...
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
Old 02-03-2003, 04:51 PM
Dalton, I dont blame you, that is a good looking car!
If you want it to look more aggressive, I'd still use stock springs in the back, and either shorter or cut stock springs in the front to give it the rake. Mine looked almost identical to the pic of the GTO you posted, and I'll be cutting my front springs this week. Unfortunately, I wont have the entire car back together for some time, so I wont have any pics for you to look at.
Also, the higher your center of gravity, the more your handling suffers(and these cars aint exactly the best handling cars on the planet anyway!)
Good luck with whatever you decide!
68 GTO bone stock
Old 02-03-2003, 04:56 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
You could look in the back of the Moog catalog for the specs on your stock springs (wire dia, free length and rate). Then try to find the same style spring that has a similar wire size but is taller or same free height but a little larger wire diameter. Don't do both though as you will have the ass end a mile in the air.
Old 02-03-2003, 11:06 PM
Tommy Bird's Avatar
Tommy Bird Tommy Bird is offline
i would think that variable rate(cargo coil)springs would be his best bet. i never liked the look of the ass-end being lower than the front end.
Tommy Doyle
67 GTO
Gulf Turquoise,400,670's, tripower,4-speed,12-bolt, p/s,4-wheel drums
87 Grand National
leaky t-tops
Tommy Doyle
79 Trans Am/Tenth Anniversary
Original W72
67 GTO - SOLD
Gulf Turquoise,400,670's,tripower,4-speed,12-bolt
Old 02-04-2003, 11:25 AM
longboard longboard is offline
I had custom coils made (local shop) for the rear of my 69 wagon. They cost $188 for both. However, they didn't raise it as I wanted. I have air shocks now, but must keep 90lbs in them to get the height I want. I am thinking of adding coil overs. Do/can they raise the car?
deane
Old 02-04-2003, 05:26 PM
JEFF KING's Avatar
Old 02-04-2003, 06:23 PM
TTS's Avatar
TTS TTS is offline
Your front is really close to the other cars height. Maybe an illusion but the other car has a lower profile tire with 15" wheels. Yours appears to have 14" wheels and a taller tire. The only difference I see is the rear. I think new rear springs will do the trick.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
Old 02-09-2003, 02:21 PM
Lobito's65Cat Lobito's65Cat is offline
How about lower profile tires for the front as well as the new springs for the rear end? How would that look?
Old 03-12-2003, 09:39 PM
mhgamber mhgamber is offline
I can relate, I have a 65 GTO Convertible (clone) and I had the wagon springs initially, but the rear was too high for me. I have stock springs which look like the rear is dragging so i tried the cheapest solution I could find. Went to autozone and got some rubber coil spriong stabilizers, cost about 9.00 bucks. just raised rear end at frame to unweight the springs and they slipped in between the coils.Thry raised the rear about 2 1/2 inches. I put some radiator hose clamps around the coils(eight total) to keep rubber blocks from sliding around. My car looks a lot better, about level now and seems a little stiffer in the rear. might be worth a try before you go drastic. Since i just spent 900 dollars on new heads I needed a cheap fix! Now to tackle more electrical bugs.....lol.
Old 03-13-2003, 06:28 AM
JoeF's Avatar
JoeF JoeF is offline
I'm not crazy about air shocks. But, my car had them in there when I bought it, and they were actually available as an option so I've left them in there (at least for now). The ride height on my car is pretty much the same as the one you show in the picture and I have only 20 psi in the shocks. In my opinion, the ride isn't any stiffer than regular shocks, but there is a little bit of a different feel to them. For the amount you are looking to raise the car, I think you can safely and comfortably achieve what you want with air shocks. That being said, if it were me, I'd probably go the spring route. Just depends upon how much time and money you want to invest.
'67 GTO Conv 400 TH400
